16 minutes ago
21 minutes ago
» Replies: 4,696
Last Post: rickcb
30 minutes ago
» Replies: 99
| From no-viz to hi-viz |
Posted by: Gone in 60 - 11-16-2020, 02:56 AM - Forum: Riding Gear
Recently, I bought a new Scorpion 420 on clearance, since the one I have is really comfy. I never liked any of the graphic designs this helmet is offered in, so I didn't care much that the new one was a few shades of dark grey and dark tan. But, I normally go with white or bright colors for safety.
I picked up a few sheets of reflective orange vinyl for a project in my warehouse, and got a little extra to experiment with on my helmet to brighten it up a bit. Here's what I came up with.
On my current crop of plain white helmets, I've gone with decals to dress them up in classic racing liveries. For the orange, I'm torn between going McLaren or Jagermeister.
| Any VFR or RC51 owners out there? |
Posted by: run-tmc_imp - 11-11-2020, 11:18 PM - Forum: Other Bikes
- Replies (47)
I’ve been obsessing over adding another Honda to my garage for awhile now as I’m concerned my CB is a little lonely out there. The two bikes I’m thinking about are the RC51 and the 5th or 6th gen VFR.
Do any of you have experience with either machine? How did it compare to your time with the CB?
Thanks! Tom
| Bike Bandit |
Posted by: LongRanger_imp - 11-11-2020, 08:07 AM - Forum: Riding Gear
I've heard from an undisclosed source that Bike Bandit may be closing its doors shortly, or at a minimum, selling off the business.
I'm not suggesting that any outstanding orders may not be filled, but just be aware in case you're considering buying something from them.
| Lithium Batteries |
Posted by: Paris_imp - 11-11-2020, 03:54 AM - Forum: Accessories/Modifications
I did a search, but the last posts on this subject were several years old, and lithium batteries have probably evolved since then.
My 2017 YUASA battery is giving up the ghost, and I am thinking about a lithium replacement. Cost is not a factor in my decision, but from earlier posts I gather that there is some concern over reliability. Unlike a led-acid or glass mat battery, lithium batteries tend to fail suddenly and without warning. OTHO, they are lighter and are resistant to self-discharging, unlike lead-acid batteries.
Does anyone have recent experience with a lithium battery, or an opinion?
| stained stainless and chrome |
Posted by: jtopiso_imp - 11-10-2020, 06:18 PM - Forum: Mechanical & Technical
- Replies (22)
Hi there,
I own a 17'RS, with double walled stainless exhaust 4-2. I thought stainless meant stain-less, but I was naive...
I've seen some on the chromed rim around the headlight, and a lot on the exhaust headers. (see pics)
First I saw it, and I thought "Oh, no, thats rust and corrosion", but I got an scotch-brite and tried to scrub it off on a small "sample area", and it's just surface "dirt".
The problem is that the scotch-brite also scratches the polished stainless (and I guess it will remove the chrome from the headlight rim), so...
What do you guys recommend to scrub this kind of surface-rust without damaging the nice-shining-polished surface below?
(A wet rug with WD40 does nothing)
| Gear Shifter Modification |
Posted by: pekingduck - 11-10-2020, 12:09 PM - Forum: Accessories/Modifications
Another Forum member asked about some particulars of a gear shift modification I posted in http://cb1100forum.com/forum/showthread.php?tid=2938.
I like having the shift lever above my foot, others have their foot angled out alongside, even some above the shifter.
The first pic shows the foot positions above the shifter for downshift, and below for upshift. Changing between means you move your toes around the shift pedal tip, and articulate your ankle through a wide range of motion, about 35-40 degrees.
What I did was to add a little tab to the shifter for downshifts only, (seen in the pic above in red oval). The rubber shift lever tip would be for upshifts, though you could still use it for downshifts. The advantage is your foot is in the most comfortable position, and just a flick of the foot for up and down shifts. The feel becomes very natural and intuitive.
The next pic shows the ones I made for my 2013, then for my 2014 which I moved to my 2017, and the last for my Triumph Bonneville.
I made mine from scrap pieces, drilled into the shifter, and put a bend in the tab portion so it accommodates various shoe thicknesses. The bend is about 30mm from the drilled hole, but the measurements are just approximations.
You could bend the tab to suit, or even rotate the strap for best fit. I've used both 5mm and 6mm bolts and nuts. The rubber or the covering on the tab is not necessary at all. If I were to make another, I would move the bolt hole 10mm forward to give more clearance on the backside.
| A question,or theory about removing engine covers. |
Posted by: FLYTYM_imp - 11-09-2020, 06:43 PM - Forum: General Discussion
I need to remove the engine covers and replace them with a set I'm having powder coated and need to get the covers off the engine. Don't want to pry or pound on anything so I've got an idea. Can't I tap some threads in a few of the mounting bosses in each cover and have these act as pushers to get the covers off?
