A question,or theory about removing engine covers.
I need to remove the engine covers and replace them with a set I'm having powder coated and need to get the covers off the engine. Don't want to pry or pound on anything so I've got an idea. Can't I tap some threads in a few of the mounting bosses in each cover and have these act as pushers to get the covers off?
In my experience, FLYTYM, no prying or pounding is required - a gentle tap with rubber-faced mallet is all that's required. The mating faces are EXTREMELY thin, thinner than I've experienced before on other 'bikes, and the slicon gasket material is correspondingly thin.
Why not have a go with one cover, before you start to drill & tap threads?
Here's my thread, where I removed my 'bike's generator cover...
[url=http://cb1100forum.com/forum/showthread.php?tid=14254&page=8]http://cb1100forum.com/forum/showthread....254&page=8
Good luck with this. I'd be interested to see how you get on with this, before/after (with pics!)
(11-09-2020, 09:09 PM)Bazbro_imp Wrote: In my experience, FLYTYM, no prying or pounding is required - a gentle tap with rubber-faced mallet is all that's required. The mating faces are EXTREMELY thin, thinner than I've experienced before on other 'bikes, and the slicon gasket material is correspondingly thin.
No drilling at all,I'm using the existing mounting holes on the cover.
Just a couple taps with a small dead blow - and they come right off.
I've had mine off several times.
You would not be able to tap the hole right to the bottom, so you'd need to grind the threads off the lower portion of the bolt you use, in order for the end to push against the crankcase. Tapping the holes might also weaken the area. In my opinion, it's just not necessary. As 'Dubs says, a couple of taps from a soft-faced mallet is all that's needed.
  Air Cleaner Covers EX/DLX michael1954 3 456 06-27-2021, 02:26 AM
  Do 2014 side covers fit a 2013? Frulk_imp 5 455 09-16-2018, 11:10 PM
Last Post: Frulk_imp
  Engine Side Covers firstforward_imp 20 1,444 01-06-2018, 09:26 AM
Last Post: tinboatcapt_imp
  Advice on removing Honda and CB1100 badges ManInBlack_imp 7 601 08-16-2017, 10:48 AM
Last Post: ManInBlack_imp
  Removing seat pittycheria_imp 20 1,517 06-15-2017, 03:10 PM
  stock side covers easyriderhatch_imp 8 602 02-08-2017, 12:17 PM
Last Post: letsjet_imp
  removing tank stickers justinrhenry_imp 22 1,315 04-04-2016, 11:23 AM
  Them ugly side covers. Ghis_imp 38 2,357 04-30-2015, 06:28 AM
Last Post: knuth11_imp
  Side covers painted? Ghis_imp 6 484 04-09-2015, 01:52 PM
Last Post: flynrider
  14 seat and side covers tried on 13 the Ferret 49 4,423 11-30-2014, 06:45 AM
Last Post: SUPERCRUZ_imp
