26 minutes ago
Last Post: The A-man
» Replies: 101
| Sena 20S EVO firmware upgrade |
Posted by: LongRanger_imp - 07-30-2020, 01:00 PM - Forum: Riding Gear
For those of you using this headset for hands-free in-helmet telephone communication, if you download and install the latest firmware upgrade from Siena’s website, your headset will no longer be able to dial or answer phone calls if you’re using an iPhone that doesn’t have the latest IOS version.
I’ve been using an old iPhone 4S running IOS 9 with my Sena without issue, until now. I’ve instead had to pair a newer iPhone to my Sena to make everything work again. It took many missed calls and a few hours of diagnosis to figure this out (it’s not documented anywhere).
| Chain Slack Adjustment...Am I Paranoid? |
Posted by: Gone in 60 - 07-29-2020, 05:16 AM - Forum: Mechanical & Technical
- Replies (26)
First of all, I've checked the forum for chain adjustment discussions. Being a super cheap individual who tries not to spend more money than I have to, I try to get as many miles out of my chains and sprockets as possible, so I clean, lube and check adjustment as frequently as practical.
Putting my new tires on over the weekend, I set the chain slack per the service manual - on the center stand, in the "looser middle" of the range - 1.25", and tweaked alignment with a laser tool. Tightened everything up, checked again and called it good.
Putting the bike cover on at work this morning, after a 13 or so mile ride from the adjustment, bike on the side stand. I decided to bump the chain up and down a bit, and it seems pretty darn loose - the bottom run of chain can be pushed up to touch the swingarm. When I get home, I'll put it back on the center stand and give it another check. I understand that on the center stand, with the swingarm deflecting down more than it would be with the wheel on the ground, it might seem tighter than it would be with the bike on the side stand.
But, am I missing anything here? Yes, I rotated the wheel and checked at multiple spots along the chain, it's pretty consistent at all points that I measured, no kinked links along the chain. Checked at the center of the run. The bike has about 5,000 miles and is on the original chain and sprockets.
| Header coating |
Posted by: Brady Bourgeois_imp - 07-28-2020, 06:20 AM - Forum: Accessories/Modifications
Hello,
Looking for information about getting the header ceramic coated on my 2013 CB1100 from someone in the US . Would like to know who does the work, how much it costs and how long it takes to complete the work. Any help would be appreciated. Thanks
| Wyoming Vacation Day Ride |
Posted by: Rexburgtom_imp - 07-27-2020, 10:11 AM - Forum: Seat Time
Jackson-Hoback-Pinedale today just for kicks. A three hundred mile day. Lots of tourist traffic and very large R.Vs headed into Yellowstone. Rained just enough to wipe all the bugs off my visor an cool off. The temp. going west back over the Teton range was twenty degrees higher. Spectacular views of the Rockies, Tetons and the Wind River Range.
| thicker grips |
Posted by: active1951_imp - 07-27-2020, 05:15 AM - Forum: Accessories/Modifications
- Replies (15)
My 2014 came with lower handlebars, but stock grips. The grips seem way too thin for machine like this. I had cruisers before this with thick grips.
I took some cord and wrapped it around stock grips, then some monkey tape on top. It really made um thicker, better and more precise gripping power.
Anyone else try any DiY grip mods OR does anyone recommend a substantially thicker grip or grip wrap?
I have tried foam stuff in past, but do not like the unsure feel.
