2013 cb1100 Left Directional Light wont cancel.
I replaced the switch already - still does it.
Left Directional Lights - Front and Rear - flash and won't cancel. When I switch to Right Directional they ALL flash.
What gives?
Thanks;
Lee
Geez you are still around and riding your CB? Been forever. Where ya been? (one of the guys from the original thread over on ADV rider before this forum was formed) Joined here in May 2013
One of the electrical gurus should be along shortly
(07-31-2020, 07:24 AM)The ferret_imp Wrote: Geez you are still around and riding your CB? Been forever. Where ya been? (one of the guys from the original thread over on ADV rider before this forum was formed) Joined here in May 2013
Hi.
Yep. Been awhile. Haven't contacted the forum since I installed the Wyverns.
That's a good one! Do you have the original turn signals, or LEDs? Any other electrical mods, or other accessories added recently?
Have a play with your "hazard switch" on the right hand side handlebars, its just below the red rocker switch, it uses the same color wires for the indicators ( orange and l blue ).
Sorry to go off topic briefly, but do you have hazard lights, Max? We didn’t get them here in Oz.
Yes, i just looked Cormanus, on the right handlebar just under the red engine stop switch in between the start button, a black slider switch with a small triangle beside it, remember mine is a japanese import.
Thanks, Max. I did remember that. It's why I asked. I can't figure out why we didn't get hazard lights in Australia unless there's some odd design rule that says they shouldn't be fitted to motorcycles.
Just a quick look at the wiring diagram (still early, need more coffee Wink ) I would check 2 things. Spray out the Hazzard switch and check the fuses.
The Turn signal relay (which is not really a relay, but a module) receives 12v from 2 different fuses. Easy check. Then I’d do the Hazzard switch as MAX said.
I looked at mine and if a turn signal is on, and you turn on the hazard flasher, all lights flash. And then if you turn off the hazard, the turn signal resumes flashing. If might be the hazard switch.
You could, if you have a meter and some electronic/electrical knowledge, pull the 2 connectors on the TS relay and meter the inputs to it. Is always possible the module failed even though none have been reported yet.
If we were closer I’d pull mine and swap it into yours, but—sorry Smile
Note, I would have posted sooner but I was hoping MAX would look into this so I wouldn’t have to (ducking for cover now Wink )
(07-31-2020, 07:51 AM)max_imp Wrote: Have a play with your "hazard switch" on the right hand side handlebars, its just below the red rocker switch, it uses the same color wires for the indicators ( orange and l blue ).
We have a Winner. The Hazard Switch was in the middle betwixt On and Off.
I have a vision of Fred Sanford staring at me, saying, "You Dummy!"
  Left side cover removal jeffmazz_imp 24 2,254 07-09-2025, 03:37 PM
Last Post: bflint
  CB1100 2013: what is the original chain relation? valkyrie_rider_imp 6 866 08-26-2024, 12:23 PM
Last Post: Randy B
  Left Side Crankcase Gasket Part number. jbird06_imp 1 338 03-26-2024, 08:56 AM
  Oil change CB1100@2013: photos valkyrie_rider_imp 12 1,199 02-14-2024, 11:25 AM
  Brake fluid flush CB1100@2013: photos valkyrie_rider_imp 0 259 02-13-2024, 10:28 AM
Last Post: valkyrie_rider_imp
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 254 02-13-2024, 10:27 AM
  2013 cb1100 chain appears to be rubbing against center stand?? Kirbythefat_imp 4 503 05-22-2023, 12:25 PM
  Short shocks for 2013 CB1100 Griz53_imp 2 407 03-23-2023, 11:38 AM
Last Post: Griz53_imp
  CB1100 Meter replaced - Speedo, ODO, not working, ABS light ON HELP! danieljrmurray_imp 14 1,308 03-31-2022, 04:03 AM
  Tank decal and the junk left behind Gordo_imp 13 1,094 09-06-2021, 02:29 PM
