16 minutes ago
» Replies: 997
29 minutes ago
» Replies: 476
» Replies: 107
Yesterday, 10:16 PM
| YTX14-BS battery |
Posted by: Gone in 60 - 04-04-2019, 08:01 AM - Forum: Mechanical & Technical
I’m hopefully going to pick up a ‘13 in a few days. The owner let me know that the battery is original and may not last too much longer.
I have a new YTX14-BS in my garage. It’s the same length and width as the spec battery for the CB, but it’s quite a bit taller looking at the dimensions on the Yuasa website.
I didn’t think to study the battery and it’s installation in the bike. I’m wondering if a taller battery would fit ok based on its location and hold down on the CB.
| Front fork oscillation under braking |
Posted by: ohiorider_imp - 04-04-2019, 06:45 AM - Forum: General Discussion
- Replies (20)
Should probably have said 'fork compresses and rebounds under light to moderate braking."
A couple of things I will try, in an effort to eliminate this.
1. First, I've swapped out the OEM fork springs, first with .90 weight, then went softer with .80 weight. Also installed Race Tech emulators. I mentioned this to the tech at Race Tech. He suggested going with heavier oil, since it was his opinion, after setting up bike forks for Race Tech for 18 years, that Honda SAE10 is too light. He reminded me that the RT valve is pretty much indifferent to heavier oil under compression, since heavier oil controls mainly the rebound damping.
2. Clean rotors with dry 3M green pad by elevating the front wheel, holding the 3M pad so that it cleans brake pad residue off the rotors as you rotate the wheel. Finish this off by wiping the rotors down with contact/brake cleaner and a soft rag. Think I'll try this first just to see if it makes any difference. Any of you cleaned your CB's rotors this way? Do you see any issues in doing so?
Bob
| clean front sprocket |
Posted by: Bronzaar_imp - 04-04-2019, 03:12 AM - Forum: Mechanical & Technical
- Replies (22)
Hello fellow CB1100 cruisers,
Since i got my liscence in january and am driving this beautifull Honda cb1100 2013, i am around 4000 km (+-2500 miles)
In allready lubricated the chain a couple of times. but now i real gonna clean it the first time. i understood it's better to clean the sprockets asswell.
Is there anyone here that can explain me how to dismantle some parts to reach to the front sprocket?
thanks in advance!
Mathieu
| Observed Valve Clearance |
Posted by: Cormanus - 04-03-2019, 07:02 AM - Forum: Mechanical & Technical
Max has kindly created a spreadsheet recording observed valve clearances to summarise data collected in [url=http://cb1100forum.com/forum/showthread.php?tid=8882]this thread.
It can be found [url=https://docs.google.com/spreadsheets/d/1oqQaAxkDBnJMwaupL8ctle85ThCTLYdyiFWDyKVbJ3I]here.
