Observed Valve Clearance
Max has kindly created a spreadsheet recording observed valve clearances to summarise data collected in [url=http://cb1100forum.com/forum/showthread.php?tid=8882]this thread.
It can be found [url=https://docs.google.com/spreadsheets/d/1oqQaAxkDBnJMwaupL8ctle85ThCTLYdyiFWDyKVbJ3I]here.
(04-03-2019, 07:02 AM)Cormanus_imp Wrote: Max has kindly created a spreadsheet recording observed valve clearances to summarise data collected in this thread.
Cormanus google now needs a "share link"for access, here it is, could you replace the old one with this one?
[url=https://docs.google.com/spreadsheets/d/1oqQaAxkDBnJMwaupL8ctle85ThCTLYdyiFWDyKVbJ3I/edit?usp=sharing]https://docs.google.com/spreadsheets/d/1oqQaAxkDBnJMwaupL8ctle85ThCTLYdyiFWDyKVbJ3I/edit?usp=sharing
God knows.......
(04-03-2019, 07:02 AM)Cormanus_imp Wrote: Max has kindly created a spreadsheet recording observed valve clearances to summarise data collected in [url=http://cb1100forum.com/forum/showthread.php?tid=8882]this thread.
It looks like the older models have valves going out of spec at higher mileage. I think I will wait until 30k miles to check mine on my 2014 model. Performance has been great and the valve train sounds great. When they start going quiet then you know that the are getting tight. That’s when you need to re-shim them so you don’t burn a valve.
These bikes chatter quite a bit from the injectors anyway..
Just done mine on a 2017 RS at 17000 miles thankfully all still in spec
(06-20-2022, 04:01 AM)shahyaan_imp Wrote: Just done mine on a 2017 RS at 17000 miles thankfully all still in spec
Excellent. Seems to be consistent with most of the Honda masses.
Does anyone here have a source for valve shims other than a dealer? Also, are the shims on the newer 1100s compatible with the 1983 model? I just found out my spare engine has a set of Andrews racing cams in it. They call for .004 inch on both sides and I will need to reset all of them when I reassemble it.
Thanks
The shim sizes are unlikely to be compatible. There are multiple shim sizes but the most popular today is the 7.5mm (7.48mm). 25mm were very popular on bikes in the 80's and 90's.
As an example, my 1995 Triumph are 25mm shim over bucket and the 2017 CB1100EX is a smaller shim under bucket. Smaller shims are used on more modern engines to reduce the mass which has to move very fast.
There are no end of online sellers. You just need to get the right diameter for your bike and then the right thickness depending on your requirements. You might find a shim kit better value for money if you have a lot to do but possibly not, it just depends on what you need and how much time you have to spare.
Here is a thread on the shim size. http://cb1100forum.com/forum/showthread....#pid304777
(09-26-2022, 07:08 PM)Tev62_imp Wrote: The shim sizes are unlikely to be compatible. There are multiple shim sizes but the most popular today is the 7.5mm (7.48mm). 25mm were very popular on bikes in the 80's and 90's.
Thanks for your input. I have 25mm shims on top. I will check with my local shop, but I don't think they will be of much help. Thay won't do a state inspection on a bike from the eighties.
  Valve Adjustment Shims dave 13 678 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 618 03-21-2026, 04:49 PM
  Valve Adjustment dave 6 852 08-29-2025, 10:46 AM
  Valve Cover Baffle lining ? bflint 6 917 07-26-2025, 11:27 AM
Last Post: bflint
  Valve Adjustment Intervals CBRider_imp 32 2,817 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,478 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
  The OBSERVED Valve Clearance thread Pterodactyl_imp 162 12,273 12-27-2022, 08:35 AM
  Checking valve clearances Maturecheese_imp 74 6,386 12-11-2022, 12:56 PM
  Valve noise (i think) Maturecheese_imp 6 620 07-08-2022, 03:41 AM
Last Post: 1973cb750
  valve adjustment jimgl3_imp 44 3,092 06-03-2021, 11:38 AM
