Weight of the OEM Wheels on the 2013/2014 std models?
I've done some looking but i can't seem to figure out any hard numbers. Has anybodoy had occasion to get an exact weight measurement of the front and rear OEM wheels without tires?
Sorry, had to remove my numbers.
Thanks so much for this Peking. I'm comparing to Aluminum and Magnesium wheels to get a handle on exactly how heavy or light we're talking about. It looks like quite a few AL wheels are about 8lbs front and 11lbs rear. Magnesium or 6.5 and 8 respectively. that's a pretty big difference.
Just for fun, I weighed a couple wheels I had lying around, no discs or sprocket drives.
2012 Triumph Thruxtons were 10.2 front, 16.9 rear.
Honda CBR250R front - 9.5
Suzuki SV1000 front - 9.8
the thruxton is probably closer to ours, all things considered. I'll keep this issue open until somebody has a source that shows the true weight of the stock wheels though.
when I bought my 2013 I did not like the partly black wheels and bought from Mr. T. a new set of wheels all silver.
However when the 2014 came out with all silver wheels I decided not to change the wheels on the 2013 and therefor I still have a new set of wheels in the basement and just weighed them.
Front 6.7 kg is 14.74 lbs. ( with bearings and air valve )
Rear 7.4 kg is 16.28 lbs. ( with bearings and air valve )
There is not that much difference as the front has two "carriers" for the discs and the rear only one.
Now you can close this thread....
The wire wheels from the 2017 are about 5 pounds lighter on the front, just over a pound lighter at the rear.
We can't close this thread until we hear from.............
(04-04-2019, 04:59 AM)Houtman_imp Wrote: when I bought my 2013 I did not like the partly black wheels and bought from Mr. T. a new set of wheels all silver.
now we're talking....though i think the AL and Magnesium wheels i've been looking at were posting their weight without the bearings and air valve. more than that, i've been mostly looking at 17 inch wheels because that's the conversion i'm considering making. So, depending on how much those bearings actually weigh, it seems like our stock wheels really are not much heavier than high end upgraded Alloy wheels, unless you go crazy and get Magnesium. frankly, if i'm going to save less than 10 lbs, i'm not inclined to spend the money. So the final comparison is:
8lbs. + bearings (aftermaket AL front) vs. 14.74lbs (OEM front)
and
11lbs. + bearings (aftermarket AL rear) vs. 16.28 lbs (OEM rear)
There is one more person i'm interested in hearing from. I seem to remember Chync put 17" spoked wheels on his bike, and i've talked to him about that conversion, but I don't have any record of what exactly his wheels weigh. He seems like the kind of guy that would have recorded that information. my first instict is that there's not really going to be any weight savings, but I could be wrong.
  Installing RLETs on a CB1100 (All Models) rdprdp01 15 1,345 09-16-2024, 12:12 AM
Last Post: Race_ca1
  Can a 2013 centerstand be installed on a 2014? WRXer_imp 1 259 11-19-2023, 04:24 AM
Last Post: WRXer_imp
  CB1100 EX tyres & wheels Ol' RedJ_imp 14 1,132 07-19-2023, 05:04 PM
  Cast wheels 18 inch on 2017 CB1100EX with Spoke wheels supruet_imp 5 635 05-13-2023, 05:43 AM
  Laced wheels ? ashishNJ_imp 3 354 02-08-2023, 01:09 PM
  Weight limit on genuine Honda rear rack DaveP_imp 14 1,192 11-17-2022, 02:57 AM
  Easy bar end weight removal brian10x_imp 6 613 06-06-2022, 01:04 AM
Last Post: 1973cb750
  How to remove both wheels? RandyBMC_imp 18 1,402 05-10-2022, 11:12 PM
Last Post: Tom_imp
  Replacing Wheels - Manual Instructions Ludicrous jasonsargonautalis_imp 12 1,215 12-11-2021, 08:52 AM
Last Post: jimgl3_imp
  Hit a Massive Pothole - Need New Wheels jasonsargonautalis_imp 18 1,459 12-09-2021, 01:33 AM
Last Post: Raceman_imp
