clean front sprocket
Hello fellow CB1100 cruisers,
Since i got my liscence in january and am driving this beautifull Honda cb1100 2013, i am around 4000 km (+-2500 miles)
In allready lubricated the chain a couple of times. but now i real gonna clean it the first time. i understood it's better to clean the sprockets asswell.
Is there anyone here that can explain me how to dismantle some parts to reach to the front sprocket?
thanks in advance!
Mathieu
Bronzaar, Who does that? Most likely no one.
However, remove the bolt and pull the shift arm off the splined shaft. Mark it first so you can put it back in the same place. Remove the screws in the cover and pull it off. Thats about it.
(04-04-2019, 05:13 AM)Lord Popgun_imp Wrote: Bronzaar, Who does that? Most likely no one.
I haven't done this on the CB, but popgun has it right.
On my Bonneville, about every other year or so I pull the sprocket cover off and clean out all the chain lube and dirt that has accumulated in there. I'm not concerned about cleaning the sprocket itself, just getting the lube out that tends to pack in there over time.
I know when it needs to be done when I can see the lube beginning to seep out from under the cover due to the heat of the engine.
Come to think of it, I've never had the cover off my 900F, but maybe I should take a look Big Grin Big Grin Big Grin
It only has 33,000 km's on the factory chain and sprockets.
Can't say I have ever done it, but may consider it now.
I Never pulled the cover off to clean in that area with almost 19.5K miles on the bike. As mentioned above. It’s not hard to do if you have the time. I’ll clean that area when I go to replaced the sprockets at the recommended intervals. I need to check on those intervals in the service manual. Might do that Saturday. It’s supposed to rain here most of the day then.
I never did that for the last 42 years! Well, 19 years of that I was riding a Kardan... Smile
Hey, it's inside a black box. It's good, if lubricated, nobody would look after it.
At least on my 2017 EX, you don't have to mark the shaft or the shift linkage; the factory put punch marks on both.
Cookie, All years should be like that. But some peopld have moved the linkage on the shaft. For instance, I moved mine one tooth AND adjusted the rod to get the pedal where I wanted it.
Since I don’t know where Bronzaar’s is set, I just told him to mark it and didn’t mention the punch marks.
ok thanks for the answers guys!
now i know i don't have to bother that much i won't do it either.
I guess the fact that it's my verry first bike ever that makes me want to be sure i do everything right to be safe. i'm verry new in motorcycles.
The guy in a Honda shop in Belgium who told me he does it every weekend must be a maniac. Or he want me to buy lube bottles as much as possible. Smile
When i bought it it had 30.000KM now it has 34.000. In the shop they said to come back at 36.000 for a first check up. I will ask them at that time to teach me about punch marks and splined shafts and such. on the spot and in dutch it will go easier.
For now i first drove a bit after work, then cleaned the chain with product i bought for this, a TON of filth came of, after it was clean i lubed it . let it rest 2 hours and then drove a bit again. done.
Thumbs Up
  Chain and Sprocket Options? Yata-Garasu_imp 22 1,980 12-23-2024, 04:47 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,214 07-30-2024, 10:05 AM
  Front sprocket bolt cant be moved misterprofessionality 55 4,455 03-13-2023, 12:18 PM
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,172 11-29-2022, 07:49 AM
  17 tooth CS sprocket install, comments. Bike #12_imp 11 953 01-03-2022, 08:30 AM
  Clean engine cutoff, starter buttons mustang462002_imp 3 390 03-19-2021, 04:13 AM
Last Post: whizzle_dizzler_imp
  How To :19 tooth front, and now, a 37 tooth rear sprocket on 2013 pekingduck 60 3,980 03-07-2021, 09:32 PM
  Another chain and sprocket question bflint 20 1,484 10-13-2020, 01:00 PM
Last Post: tod.branko_imp
  Alloy Sprocket woes Ninemeister_imp 22 1,628 09-24-2020, 09:23 AM
Last Post: Ninemeister_imp
  Broken rubber on front sprocket zirconxi_imp 7 550 05-24-2020, 11:17 AM
Last Post: zirconxi_imp
