» Forum posts: 263,269
There are currently 301 online users.
» 3 Member(s) | 296 Guest(s)
Baidu, Bing, JRD, MagnaRider, pekingduck
18 minutes ago
» Replies: 976
24 minutes ago
Last Post: Serge from France
» Replies: 452
Yesterday, 01:11 PM
Valve Adjustment Shims
07-28-2026, 12:49 PM
  Like Button Plugin Is Enabled
Posted by: rdprdp01 - 04-25-2025, 04:01 PM - Forum: Release Notes - Replies (7)
For all posts. Please see bottom of post. Let Members know when you really like their posts.
  Quote Function Is Operational
Posted by: rdprdp01 - 04-24-2025, 10:39 AM - Forum: Release Notes - No Replies
This morning, I confirmed that the Quote Function for replies is working on this site. See supporting documentation from MyBB. It is clunky to say the least. I will see what can be done to streamline things a bit. We may be at the mercy of the developers. Hopefully, more to follow. But for now, this is how things work:
To quote a post in MyBB, simply click the "Quote" button located below the post you want to quote[/color]. This will automatically insert the quoted text into your reply form, making it easy to respond and reference the original post.
Locate the "Quote" Button. Look for the "Quote" button, usually found beneath each post. It might have a speech bubble or quotation mark icon.
Clicking the "Quote" button will automatically populate your reply form with the quoted text.
You can then write your reply, and the quoted text will be included, making it clear which post you are referring to.
  Spring 2025 Sakura - Cherry Blossoms
Posted by: venturer434_imp - 04-24-2025, 01:42 AM - Forum: CB1100 Photos & Videos - Replies (4)
Start of our riding season with Cherry Blossoms in full bloom.
  Map embeds in posts
Posted by: Cormanus - 04-23-2025, 01:34 PM - Forum: Suggestions - Replies (6)
MrP, mea culpa! While working on this problem, I managed to delete the thread along with a post I made. Would you please be kind and post an embed link for a map again? Could you also tell me how you generated it in Google Maps?
  How much do stock pistons weigh?
Posted by: jikemenkins - 04-23-2025, 10:55 AM - Forum: Mechanical & Technical - Replies (4)
Hello all,
I'm curious if anyone knows, or has a source for the weight of the stock pistons? I'd take wristpin and conrod weights as well if anyone knows those, or a likely source.
Thank you for your time.
Mike
  New shoes...
Posted by: Whoops - 04-23-2025, 04:54 AM - Forum: Other Bikes - No Replies
New shoes for the Twin today. I thought I would give the Dunlop Trailmax Mission's a try since they are apparently a long wearing and very popular 50/50 tire.
[Image: f7ea7c4b452fcb31fe8affc9df30cdc3.jpeg]
The factory equipped Bridgestone Battlax Adventure A41's didn't last 6k miles. The sides of the front tire wore down faster than the center. That made turn-in's a bit sketchy as the bike would go from barely turning to plunging into the turn so much that I felt like I had to fight the transition, especially on gravel. Both of them reached their wear bars at about the same time, which is nice. The center of the rear seemed so thin I was worried about a rock puncture on my last ride.
  Conducting Business Transactions
Posted by: rdprdp01 - 04-22-2025, 11:59 PM - Forum: Selling Items on the CB1100 Forum - No Replies
Our CB1100 Community encourages motorcyclists to share ideals and experiences that can enhance owning, maintaining, and riding one of the great motorcycles of all time: the CB1100. In some instances, a Forum member may create new products that are of value to other Forum Members or own a motorcycle that needs a new home. You are welcome to post those products or list that motorcycle in the appropriate section of the Forum. Please be advised that all financial transactions between Members are, by their nature, financial transactions between two Members and are not in any manner regulated or controlled by the CB1100 Forum or its Administrators, Moderators, or Developers. The Forum does not extend any warranty for any purchase, nor should any misunderstanding or conflict appear in a Thread or Post. Please handle those situations privately.
If, for whatever reason, a particular Thread involving a purchase is deemed distracting, Forum Moderators reserve the right to remove that Thread from the Forum.
  tire options - non standard size question
Posted by: tdbru - 04-22-2025, 10:42 PM - Forum: Parts For . . . - Replies (16)
I guess tires are parts, right?  anyway, will a 150/70R18 fit on a 18" x 4" rim acceptably.  looks like 4.25" rim width is "ideal" but would it work on a 4" wheel width?  the swing arm looks plenty wide for another 10mm in width, but the present 140/70R18 comes a bit over 1/2" from the swing arm cross brace.  1/2" is 12.7mm.   70% of 140 is 98mm.  70% of 150 is 105mm.  going by straight calculations it looks like a 7mm increase in radius would fit.  Has anyone tried a 150/70R18 yet before?  if so, how did it turn out for handling?
thanks,
tdbru
  Slight Oil Leak
Posted by: DutchRutter - 04-22-2025, 09:55 AM - Forum: Mechanical & Technical - Replies (22)
Hello fellow CB people!
Its been a while since I posted anything about my 14.
The other day I noticed a small looking oil seep left hand side, toward the top, rear right under the valve cover. I did a search and found that other have had this same leak and it ended up going away on its own.
I cleaned the area in hopes mine would do the same but as of this morning, no dice. I now have fresh oil in that same spot. (kind of hard to see in the picture but its there) just on top of the top cooling fin. I want to say its originating from the valve cover gasket itself, maybe even a little from the gasket nearer the center of the valve cover.
[Image: b8aa47ec81189c6cd03911ec01c079ac.jpg]
Has anyone replaced the valve cover gasket themselves? Looking at it, I don't think it would be too difficult assuming there is enough space to take it out without pulling the engine. and would there be any other seals etc. needing replaced or just the gasket itself?
  Motorcycle Row (Pleasanton, CA)
Posted by: rdprdp01 - 04-22-2025, 07:29 AM - Forum: CB1100 Photos & Videos - Replies (2)
Downtown Pleasanton is a lovely destination place. It has a motorcycle row nexts to the Peet’s coffee. One morning, I parked my CB1100 EX next to a V-Rod and another Harley. Both had after market kits that cost more than my CB1100 EX. Bias that I am, I believe the stock CB100 EX represented itself well! Both owners of the other motorcycles chatted with me about the build quality and were amazed our motorcycles rolled out of the factory with such high-quality components.
https://www.pleasantondowntown.net/
[Image: 6AOQzsu.jpeg]
[Image: Nbne8qt.jpeg]
