NGK spark plug options
Hi, firstly please forgive me if this has been posted before but here in the UK NGK only have one spark plug listed for our bikes - LMAR8A-9S, which we all know is just the standard type.
I see that upgrade "high performance" plugs have been found listed in Japan, but I found that the Honda Africa twin uses the NGK iridium version of our standard plug and has the all important stainless sealing washer.
Part number SILMAR8A-9S (90992)
These are super expensive here in the UK but they will be easier to find as the Africa Twin is very popular world wide.
Just another option for any high milers on here that hate changing plugs! LOL!
Ride safe folks,
JT
(11-08-2024, 08:49 PM)Jonnyteabag_imp Wrote: Hi, firstly please forgive me if this has been posted before but here in the UK NGK only have one spark plug listed for our bikes - LMAR8A-9S, which we all know is just the standard type.
Ride safe folks,
JT
I thought that the s on LMAR8A-9S stood for Stainless washer these are about £13.50 in the UK from places like Demon Tweeks. Who incidently have SILMARA-9S on special offer with 52% off
https://www.demon-tweeks.com/ngk-iridium...lsrc=aw.ds
“I found that the Honda Africa twin uses the NGK iridium version of our standard plug . . . Part number SILMAR8A-9S (90992)“
This is not correct. The SILMAR8A-9S plug has a different terminal configuration.
The CB1100 plug terminal is thinner and ridged. The Africa Twin plug terminal is wider and smooth. It does not fit.
Whatever ya do, don't buy NGKs from eBay or Amazon. I got a set of fakes on eBay for our CRV when it hit 100k. The car started bucking at 110k, and I found that the ground electrodes on two of the plugs had evaporated. Checked NGKs site, and they had a warning on how to spot fake plugs, and mine definitely were.
I contacted NGK customer service and asked if they have any high performance plugs that were compatible with the 2017 CB1100. They indicated that the NGK 91909 LMAR8BI-9 are compatible with the bike (https://www.sparkplugs.com/ngk-91909-lma...spark-plug)
I will order some and report back.
(08-02-2026, 06:11 PM)JRD Wrote: “I found that the Honda Africa twin uses the NGK iridium version of our standard plug . . . Part number SILMAR8A-9S (90992)“
You remove the screw on tip. Per NGK's own cross reference it is a direct cross.
Posts: 2,500(0.57 per day | 0.79 percent of total posts)
Registration Date: 04-26-2013, 09:56 PM
Interesting. I didn’t realize that the plug terminal unscrewed and I wasn’t going to just start yanking on it with pliers to see what would happen. Sounds like we have a few options! That’s an unfamiliar feeling for a CB1100 owner.
  Booster Plug on an RS TheLegend 6 475 04-22-2026, 06:31 AM
Last Post: TheLegend
  spark plugs after 70.000 Km DAC 16 1,458 12-23-2025, 10:15 AM
  What is this plug? MagnaRider 7 683 02-13-2025, 03:39 AM
Last Post: MagnaRider
  Chain and Sprocket Options? Yata-Garasu_imp 22 1,952 12-23-2024, 04:47 AM
  Tire Options for our CB1100 Bike #12_imp 528 38,020 12-19-2024, 04:27 AM
Last Post: Whoops
  'Factory' high performance spark plugs PowerDubs_imp 17 1,466 10-23-2024, 02:50 PM
Last Post: rtmoto1
  Spark plug socket. Jgarciajr40_imp 5 543 09-11-2023, 10:40 PM
Last Post: Jgarciajr40_imp
  Software options? josh mcelfresh_imp 2 358 08-09-2023, 03:46 AM
Last Post: josh mcelfresh_imp
  spark plugs NGK LMAR8A-9S louied_imp 1 323 06-27-2023, 01:19 PM
  spark plug caps alexzanutto_imp 3 384 01-29-2023, 06:21 AM
Last Post: artashline_imp
