» Forum threads: 14,187
» Forum posts: 263,377
There are currently 744 online users. » 1 Member(s) | 738 Guest(s) Applebot, Baidu, Bing, Google, Yandex, the Ferret
» Replies: 5,461
» Replies: 4,693
» Replies: 97
Today, 09:12 AM
Today, 01:54 AM
Yesterday, 05:07 PM
| Higher Tire Pressure = More Suspension Compliance? |
Posted by: Huladog_imp - 07-27-2014, 11:24 AM - Forum: General Discussion
- Replies (24)
Just wanted to run this by you guys to see if I'm nuts or not.
When the CB1100 suspension starts to feel harsh and jarring (and I start thinking of fiddling with the preload or worse, spending $ for replacement shocks) I remember to check the tire pressure.
Find out they're both maybe 5-6 pounds low, so I pump them back up to 36 front/42 rear and then the stock suspension seems relatively plush, compliant and composed again.
Seems sort of counter-intuitive if you ask me.
Higher (proper) tire pressure seems to make the ride compliant as if the road shocks are now able to be absorbed by the suspension as designed. Low tire pressure and the ride seems harsh like the road shocks don't get transmitted to the suspension although you would think the softer sidewalls would absorb road shocks.
Am I nuts?
On my previous BMW R1200RT it was sensitive to tire pressure and turn-in/handling definitely improved running higher that spec'd pressures. Before that my Street Glide needed proper tire pressure just to turn-in at all.
Just wondering if anyone else noticed something similar?
Aloha,
Huladog
| A few mods on a 2013 |
Posted by: tintoy_imp - 07-27-2014, 01:44 AM - Forum: Accessories/Modifications
Some pictures of the small mods on my 13 CB1100.
*Corbin Seat.
The first Corbin I had was on a 2009 Triumph Bonnie. Corbin tells you that the seat may seem rather hard until you put about 2k miles on it, and they are right. After it breaks in it is very comfortable. This time I went for the leather, not vinyl, and it is proving well worth the cost.
The original seat was just too soft and my butt would sink down into the foam comfortably, but that same foam would then push up on 'the boys' and after awhile became very uncomfortable. OUCH!
[url=http://imageshack.com/f/kp5Dv3qjj]
*Forward Footrests.
These are passenger foot pegs from a 83 CB450A mounted to some good steel brackets purchased at the local hardware store drilled and bent to fit. The foam covering, same stuff used to cover hot water pipes, keeps them from getting pitted and rusting.
They do the job, and I only ever use them one at a time on longer rides.
[url=http://imageshack.com/f/iphzGqC7j]
*Handlebar Risers.
From a 96 Honda Magna. They raised the bar up about 2 inches and back about 1 inch. I had to reroute the front brake line behind the triple tree, but the wires and clutch line worked out just fine.
I would like to bring them up another inch or so but that will require at least extending the upper brake line or replacing the original with two separate lines or a custom line. I think I'll wait on that for awhile.
[url=http://imageshack.com/f/ewf1Sx38j]
*Rear Shocks.
I guess I just don't weigh enough (150 lbs) because the only way I could get the rear shocks to work was to lift up and plop down real hard. They are just too stiff for a good safe ride. I'm just not into hard tails and skiddering around corners.
These are from a Harley XL1200. They are softer and as a bonus they dropped the rear about 1 inch. I had to replace the Harley bushings with Honda CB1100 parts and use small washers to space the lower bolts out about 1/8 inch so the larger stock washers would not push directly on the chrome of the shock when tightened down.
[url=http://imageshack.com/f/f00lbRQnj]
*Slipstreamer S-02 Spirit Windscreen.
This is a nice windshield. If you want something more than a small screen you might want to consider one of these.
At first I had it mounted higher up and back further but it created to much turbulence on me. Where it is now is just about perfect, no turbulence, good airflow, and it even keeps the wind of my hands. I've had the bike up over 95 mph with no ill effects due to this shield. Perfect for cruising or commuting. It does not feel like I'm plowing air either.
[url=http://imageshack.com/f/ezYLxeaxj]
[url=http://imageshack.com/f/ipMwHnGIj]
[url=http://imageshack.com/f/iqk7GUYMj]
My next mod will be changing the front sprocket to 19 teeth.
tintoy
| Black side covers |
Posted by: ScottSny_imp - 07-26-2014, 11:11 AM - Forum: General Discussion
I have been thinking about changing the side covers for a while and decided to see what it would look like. Got a can of the rustoleum version of plasti dip and sprayed them. I really like the black and think that a permanent flat black paint job is on the way. The rubber stuff will come off to easily for a permanent job. Also wondering if I could just buy them in black and put away the originals. Anyone?
| Bonneville vs CB1100 |
Posted by: Dvassino_imp - 07-26-2014, 10:27 AM - Forum: General Discussion
- Replies (54)
I know this must have been a topic before, but can anyone who has some experience with both of these bikes give a comparison. I love the look of both of these bikes and need to make a decision next week. 2014 CB1100 Dlx or 2014 Triumph Bonneville.
Thanks,
Dino
| Smokin' deal on a chain tool. |
Posted by: flynrider - 07-26-2014, 10:17 AM - Forum: Mechanical & Technical
- No Replies
While preparing to put a new chain on the CB750, I realized that my chain tool had apparently moved to Florida, with the neighbor that last borrowed it.
Luck was on my side when I happened across this deal over at Cycle Gear. It's the same one I used to have. It works great for breaking, pressing and riveting links. Most tools that do all three functions are usually in the $80-$90 range. Cycle Gear is selling this one for $40. They're available both online and in the store for that price. I'm not sure how long that price will last, so you better hurry if you want one.
http://www.cyclegear.com/CycleGear/Acces...it/p/36518
