02-17-2018, 10:53 AM
(02-14-2018, 04:00 AM)911jimmy_imp Wrote:>>>>>>>>>>>>>>>>(02-13-2018, 10:28 PM)peterbaron_imp Wrote:>>>>>>>>>>>>>>>>(02-13-2018, 02:34 PM)911jimmy_imp Wrote: Okay guys it sounds like you've done so much amazing work thank you so much!!>>>>>>>>>>>>>>>>
I just want to clarify a few things for those who were wondering, the motorcycle was crashed really hard on a Canyon Road, it's near $6,000 in parts later to get to this point and the gauges were destroyed ..
The original owner unfortunately threw the gauge pieces away otherwise I would have totally left that part plugged in and had it hidden under the seat.
As you can see in the photo none of that stuff exist anymore and min of $1000 more just for the stock gauges which are too bulky for the custom motodemic headlight setup..
THANK YOU CORMANUS & POP
I BELIEVE CORMANUS ANSWERED THE QUESTION, AND ITS GOOD NEWS !! THE 2013 BIKE WILL RUN WITHOuT THE GAUGE ..
SO NEXT STEP IS GETTING THE 2013 WIRING AND ECU AND WE SHOULD BE ABLE TO GET IT GOING ..
*POP*
ALSO WANTED TO NOTE THE KOSO GAUGE HAS ITS OWN SPEED SENSOR & WIRING THAT WEVE INSTALLED ON THE FRONT BRAKES INDEPENDENT OF ECU
I WILL UPDATE AS THIS GETS DONE AND FIGURE OUT HOW TO POST THE BETTER PICTURES , BECAUSE THE BIKE CAME OUT SO NICE ...
NOT so fast..
As popgun & others already mentioned 2013 2014 wiring harness is different = for sure !!
Swapping partial harness with ECU ( if it comes in few separatable sections) may not work.
Also Ulvetanna is correct with his statement:
"If you were to tear apart the gage housing, you would find computer circuitry needed to process the bike's data critical to operation.
If you were really clever you could remove only the circuit boards needed, put them into a small, separate housing, and locate that inconspicuously somewhere, like, under the seat. Run the CANBUS line to it and connect everything exactly the same as if it were the gage cluster.
The mechanical gages don't need to be connected, but, who knows how they've been integrated into the circuitry? The whole thing may be nearly impossible."
You may also have an issue with a VIN reading or writing after swapping..???
Now days with the electronics, ECU, VIN, CAN+++ it becomes very difficult if not impossible to interchange/swap parts from other vehicles. Manufactures do not want anybody to buy parts from aftermarket or wreckers, only OEM, they mean business.
Your project needs deeper study prior spending money with no results..!!
Be aware what you digging into, and I doubt if anybody can clearly say "yes , it's gonna work"
pb
NOT so fast..
pb \
THANKFULLY THESE BIKES DON'T HAVE ANYTHING LIKE THAT.... ONLY ONES THAT I KNOW OF THAT HAVE SUCH ISSUES ARE ITALIAN BIKES LIKE DUCATI, APRILIA.... HONDA HASNT COME THAT FAR YET, WE CAN MODIFY THE HARNESS IF NEED BE OR WE HAVE NO PROBLEM GETTING WHATEVER IS NEEDED FROM THE 13 INCLUDING THE ENTIRE HARNESS.
WILL UPDATE WITH IMAGES.
NOT so fast..
pb \
TODAY, I took a second = more precise look at 2013 and 14 ECM electrical/sectional diagrams ( this excludes wiring diagram for the rest of the bike, like lighting, starter, alternator...) .
Based on possessed shop manual, my observations are as follows ::
1* both ECM look very similar - do not want to state "identical", even if these have different OEM part number, practically might be interchangeable (assuming NO VIN writing needed)
2* pins location, connectors/plastic housing very similar - if not "identical"
3* even if 2013 has ABS and 2014 doesn't, both ECM may have identical motherboards and some circuits may not be used - depending on the bike MY
I cautiously would say that from previous "not so fast", I now could say:: If one is smart enough with electrical/electronics, knows how to switch pins location, decipher +++, incorporating two different harnesses/meters from 2013/14 might work for your particular project.
Above note does not interfere with or negate other members advice.
Good luck with your plan, which seems to be now more realistic
Let us know, pics mandatory, as the Forum members and moderators love to see.
pb
![[Image: 0327dfb8d00e426108950e5bd2385e8d.jpg?dl=0]](https://cb1100forum.net/forum/uploads/imp/201802/0327dfb8d00e426108950e5bd2385e8d.jpg?dl=0)
![[Image: e8d70ee9ef3113789d1766ad7685b70c.jpg?dl=0]](https://cb1100forum.net/forum/uploads/imp/201802/e8d70ee9ef3113789d1766ad7685b70c.jpg?dl=0)
