Easy bar end weight removal
Just roll the grip back, insert 7/8" open end (or for you metric users, 38.4 kilograms)and pound the crap out of it with a mallet.
Easy-peasy. You destroy the retaining clip, but, you aren't putting it back in, are you?
Second pic is the Amazon throttle lock. Kind of a POS. Had to install a hardware store washer to make it work.
Brian, you are missing a lot of very helpful information on this forum. I am pretty sure there are two pins on the end of the weight that you simply compress, or press in, and the weight slides out. There are posts about it on this forum. Maybe yours didn't have them, but I know mine (2013 Standard) does.
Is "Amazon throttle lock" kinda like the "AliExpress throttle lock" in terms of quality? Maybe the same thing?
(05-29-2022, 05:57 AM)Nachodaddy_imp Wrote: Brian, you are missing a lot of very helpful information on this forum. I am pretty sure there are two pins on the end of the weight that you simply compress, or press in, and the weight slides out. There are posts about it on this forum. Maybe yours didn't have them, but I know mine (2013 Standard) does.
I've seen that method before, but this is easier.
1-Shove the open end between the grip and bar end.
2-Hit once or twice with heavy mallet.
3- Pop goes the weasel!
(05-29-2022, 05:58 AM)GoldOxide_imp Wrote: Is "Amazon throttle lock" kinda like the "AliExpress throttle lock" in terms of quality? Maybe the same thing?
Probably. The Kaoko is much more expensive, but much superior quality. years ago, I had a Throttlemeister on my ST1300. THAT is what I really want. Too bad they are out of business.
I'm going to try this one out for awhile. I hope I don't end up regretting the purchase and buying something better.
"Buy once, cry once" I need to heed my own advice.
I use the Kaoka and I am happy with its predictable functionality. Seems indeed reliable.
Thanks brian10x, just wanted to be sure you had the info if you needed it.
For anyone wanting an excellent description and great photos about removing the handlebar end weights, this link should help:
http://cb1100forum.com/forum/showthread....=handlebar
I have that throttle lock its junk threads are cut the wrong way and doesn't hold the throttle like it should
  Valve Adjustment and Camshaft Removal dave 5 631 03-21-2026, 04:49 PM
  Left side cover removal jeffmazz_imp 24 2,166 07-09-2025, 03:37 PM
Last Post: bflint
  Weight limit on genuine Honda rear rack DaveP_imp 14 1,245 11-17-2022, 02:57 AM
  HELP GAUGE REMOVAL /CUSTOM TACH 911jimmy_imp 96 6,083 07-25-2022, 06:54 AM
  Easy RLET installation, using a sheep castrator willsmith_imp 60 4,552 02-03-2022, 06:26 PM
Last Post: Bazbro_imp
   CB's max weight j3gq_imp 36 2,616 11-26-2020, 11:32 AM
  Air box removal ACE_IRA_imp 23 1,671 09-25-2020, 05:56 AM
Last Post: ACE_IRA_imp
  Wheel weight Brad14_imp 7 587 07-25-2020, 01:56 AM
Last Post: Brad14_imp
  Fuel Tank Removal Gabby_imp 11 948 06-19-2020, 10:54 AM
  Throttle tube easy to fit? Buzzard Biker_imp 9 703 02-28-2020, 11:21 PM
