Clock Speedo and Tach died while riding
Hi all? Today I was out riding and after hitting a bump my Speedo tach and clock all shut off I tried restarting the bike but nothing. I am wondering what may have caused that and what the fix may be. I’ll add that this is a 2013 cb1100.
The instrument cluster is supplied from fuse D and this fuse also supplies the tail light and an accessory connector inside the headlight bucket, do you have any accessories connected to this 2 pole connector?.
It is the third red 10 A fuse from the right " meterillum "
So if the tail light is out also it is this fuse under the seat.
There may be a reason the fuse disconnected like a short to ground somewhere, you may be able to spot this by watching the harness for possible wear points.
if the tail light is working it could be a black 10 pole connector in the headlight bucket not making good contact.
If that is not the case it is the connector inside the instrument cluster, you may test this by tapping the case and see if the meters come back.
(06-14-2022, 04:14 PM)max_imp Wrote: The instrument cluster is supplied from fuse D and this fuse also supplies the tail light and an accessory connector inside the headlight bucket, do you have any accessories connected to this 2 pole connector?.
That's a great approach to troubleshooting electrical faults - Get a paper solution first before looking at the bike Idea
  Speedo & Tacho chrome covers Chris Goldson_imp 22 1,688 05-23-2026, 04:43 PM
Last Post: LucienLeFranc
  Clock Cormanus 32 1,827 05-19-2026, 08:51 PM
  CB1100 EX fueling & speedo Ol' RedJ_imp 7 624 07-16-2023, 02:17 AM
   Digital tach shorting out kentf1120_imp 1 245 03-16-2023, 09:33 AM
  HELP GAUGE REMOVAL /CUSTOM TACH 911jimmy_imp 96 5,832 07-25-2022, 06:54 AM
  CB1100 Meter replaced - Speedo, ODO, not working, ABS light ON HELP! danieljrmurray_imp 14 1,233 03-31-2022, 04:03 AM
  2014 Metric European Speedo peterbaron 25 1,838 07-28-2021, 09:16 PM
  Circuit board behind speedo 1300x4_imp 6 466 02-22-2021, 10:55 PM
Last Post: max
  Digital Clock Faulty? bertypower_imp 21 1,438 09-08-2020, 09:10 AM
  Speedo/Tacho Gauge alignment? Richard_imp 34 3,430 02-20-2020, 12:29 PM
