CB 900C Custom Spark Issue
Hi
I am troubleshooting a spark issue. Is the spark pulse area supposed to have oil in it?
Hello Howdy goatman. This forum mainly deals with the 2010-2020 CB1100 series of bikes, but maybe someone will know the answer to your question as it pertains to an older Honda
There's no crankshaft seal on that left side, but the left cover has a gasket and the smaller cover has an o-ring, so there is some oil in there that should be okay.
That generation of Honda 650/750/900/1000 had a pair of igniter boxes that often fail over time, with the epoxy potting melting to goo.
Nevertheless goatman64, welcome to the Forum!
Don't look too hard at the CB1100. It might cause conflict. Smile
  NGK spark plug options Jonnyteabag_imp 7 697 08-18-2026, 07:48 PM
Last Post: SportsterDoc
  Help from the hive mind: Intermittent Starter Issue (2017) JRD 10 583 01-30-2026, 02:16 PM
Last Post: JRD
  spark plugs after 70.000 Km DAC 16 1,674 12-23-2025, 10:15 AM
  'Factory' high performance spark plugs PowerDubs_imp 17 1,520 10-23-2024, 02:50 PM
Last Post: rtmoto1
  Shifting issue Cormanus 31 2,524 05-15-2024, 12:59 AM
  Spark plug socket. Jgarciajr40_imp 5 588 09-11-2023, 10:40 PM
Last Post: Jgarciajr40_imp
  spark plugs NGK LMAR8A-9S louied_imp 1 342 06-27-2023, 01:19 PM
  Arrow Slip on issue - stock gasket didn’t fit Ddawg1144_imp 4 483 02-21-2023, 07:51 AM
  spark plug caps alexzanutto_imp 3 434 01-29-2023, 06:21 AM
Last Post: artashline_imp
  spark plug help, please !! The Gecko_imp 10 807 10-08-2022, 12:22 PM
