Fuel gauge flashing from center outward....
Like I said, it flashes from the center outward. Not low on fuel. Sometimes it stops right away, other times it will continue flashing a long time. Anyone ever experience this? Think my fuel gauge in tank is sticking?
The service manual actually has drawings that show this. Indicates a fault in the guage circuit.
Then says to check some wires. If the Gray/black wire is OK, then the fuel level sensor is good, and if so replace the meter assembly.
Anyway, I would first check the fuel pump connector as a first step. Unplug it and make sure the pins are seated well and are not corroded or anything. There is a proceduure for checking the sensor (fuel level ). If you would like, PM me your email and I’ll send it to you.
(03-19-2018, 05:53 AM)Lord Popgun_imp Wrote: The service manual actually has drawings that show this. Indicates a fault in the guage circuit.
Oh, cool. Thanks. I didn’t check my service manual for it yet. It just started a few days ago. Appreciate the response. [Image: c90be1e3dad26b2e32cc3e8c18e1898e.png]
Look in section 19, page 19-28 for 2014 models.
So I finally checked out the fuel pump/gauge unit in the tank. I didn’t see any visible problems and I still get the warning. Has anyone else had this warning before? Anyone? Bueler?
General info:
What year= provide info!!!!! 2013 = 3 wire, 2014 = 4 wire (pump&unit assy)..others = have no info:
Do a sending unit sweep and resistance tests = have to take unit out of gas tank...or have a variable resistor to test gas gauge itself for smooth-intermittent-erratic operation
pb
(06-20-2018, 05:33 AM)peterbaron_imp Wrote: General info:
pb
Mine is a 2014 Standard. It doesn’t give warning when when I fill the tank but I’ll ride it home about a mile and park it until next morning and then the warning starts. Also, the warning will stop when fuel is getting low, (1 bar showing)
still under warranty?
(06-20-2018, 06:47 AM)The ferret_imp Wrote: still under warranty?
Oh no. Warranty ended many moons ago. [Image: 44193dd63c6e42c4cddb7d4f285d20ff.png]
pb
Would be better and less complicated for you if you follow popgun instructionTongue, providing you have service manual...p 19-28 as he said
2014 = 6 bars
Good luck
pb
  Center stand and new chain / sprockets jermo47_imp 8 879 04-24-2024, 10:55 PM
Last Post: jermo47_imp
  2013 cb1100 chain appears to be rubbing against center stand?? Kirbythefat_imp 4 494 05-22-2023, 12:25 PM
  HELP GAUGE REMOVAL /CUSTOM TACH 911jimmy_imp 96 5,920 07-25-2022, 06:54 AM
  Explanation of 2014 Fuel Gauge the Ferret 28 1,899 04-27-2022, 01:46 PM
Last Post: ChiefJP_imp
  HISS flashing Maturecheese_imp 7 662 03-23-2022, 09:34 PM
  Don Guhl video on ecu flashing max 8 622 09-08-2021, 02:52 PM
  center stand cj599_imp 12 914 04-17-2021, 03:03 AM
Last Post: cj599_imp
  ABS Light Flashing on 2017EX iamheero_imp 45 3,339 09-14-2020, 07:36 AM
  Speedo/Tacho Gauge alignment? Richard_imp 34 3,503 02-20-2020, 12:29 PM
  Center Stand Doesn't Always Retract Fully emptysea 4 340 01-03-2020, 04:47 AM
Last Post: LongRanger_imp
