Left side cover removal
Can someone help me with the left side cover removal? I have the gasket released but the cover comes off about 1/4" and stops. It feels like there is something in there not allowing it to fully release. Should I keep pulling or is there something I'm missing? The electrical wire that goes in the top isn't the issue. Also does anyone have the torque values for the cover bolts?
Any advice will be greatly appreciated.
Jeff
Are you talking about the alternator cover? The side covers are the triangle shaped plastic things with CB1100 on them Smile
Anyway, if it is all ready to come off, the book has a note that says, The cover (stator) is magnetically attracted to the flywheel, be careful during removal. I’d try pulling harder. It also says to remove the starter gear reduction gear cover and remove the gear shaft and reduction gear then take the cover off.
Give me few minutes and I’ll look up the torque value.
In the drawings and installation procedure and torque table list there is no torque value listed. Just says tighten in 2 or 3 steps. So, you have to use the Standard Torque Value table. For 8mm it says: 8mm hex bolt and nut—16ft lb. For 8mm flange bolt and nut—20 ft lb.
(10-27-2017, 08:34 AM)Lord Popgun_imp Wrote: Are you talking about the alternator cover? The side covers are the triangle shaped plastic things with CB1100 on them Smile
Thanks popgun! It is the alternator cover. I did remove the starter gear reduction cover and gears. I'll give it a harder pull and see what happens. Thanks again!!
Alternator cover replaced. It was a little more difficult than I thought it was going to be but she's done. Popgun, thanks again for the information.
Glad you got it! Why did you have to take it off?
Popgun, the answer to your question is in this thread http://cb1100forum.com/forum/showthread.php?tid=11521
Thanks again for your help.
An old thread this, but it caught my eye 'cos this is exactly what I face when I get home to repair my new CB...
Despite the damage, the engine runs fine.
[Image: 45f4e37c91643ef8947e2df57fee31a1.jpg]
(03-20-2019, 06:52 AM)Bazbro_imp Wrote: An old thread this, but it caught my eye 'cos this is exactly what I face when I get home to repair my new CB...
Yikes! Wow. Still not a sight one wants to see.
Such a shame - and only 165 miles on the clock!!
(03-20-2019, 07:48 AM)Bazbro_imp Wrote: Such a shame - and only 165 miles on the clock!!
I am wondering if it was a tester model? Maybe you already said something about the bike in the Forum.
I have heard first hand a tester rider totaling a Ducati Diavel. Sad
  Valve Adjustment and Camshaft Removal dave 5 647 03-21-2026, 04:49 PM
  Left Side Crankcase Gasket Part number. jbird06_imp 1 339 03-26-2024, 08:56 AM
  HELP GAUGE REMOVAL /CUSTOM TACH 911jimmy_imp 96 6,603 07-25-2022, 06:54 AM
  Easy bar end weight removal brian10x_imp 6 626 06-06-2022, 01:04 AM
Last Post: 1973cb750
  Question on replacing engine side cover Ollie 11 829 01-10-2022, 11:21 AM
Last Post: Ollie
  Tank decal and the junk left behind Gordo_imp 13 1,101 09-06-2021, 02:29 PM
  2014 Right Side Cover--Red eddi0_imp 12 1,217 06-07-2021, 09:16 PM
Last Post: eddi0_imp
  left crank cover calipo223_imp 3 404 05-05-2021, 06:29 AM
   Fuel line connection came undone and left me stranded! Riko_imp 33 3,776 12-04-2020, 12:29 PM
Last Post: 17-CB-002
  Air box removal ACE_IRA_imp 23 1,789 09-25-2020, 05:56 AM
Last Post: ACE_IRA_imp
