Air box removal
Lads can’t remove air box.unscrew all bolts up to stage pull it back can’t move it.I have manual lads no need of pic.Just need a tips maybe some hidden bolt left.
There is a fwd and aft section - which one? If it's the aft air cleaner housing, did you loosen the connecting boot band? (page 5-57 of my Honda shop manual).
(08-27-2020, 10:05 AM)Dave_imp Wrote: There is a fwd and aft section - which one? If it's the aft air cleaner housing, did you loosen the connecting boot band? (page 5-57 of my Honda shop manual).
That first part where air filter mounted itself.I think that’s the bolt I cannot find.Its from oil cap side?
ACE, are you trying to take the filter out? If so, there's 3 screws. The third is right up to the top right of proceedings as you face the right-hand side of the bike. It might even be lurking behind some wires. Have a good look with a torch.
Torch is a flashlight !
there is one down low and to the right you have to push wires out of the way to see and it helps to have a long shanked jis or phillips screw driver for removal and reinstallation
Thanks lads 4 ur help really appreciate it.Do u need to remove rear fender as well?
I'm confused are you taking out the filter or the whole filter box?
[quote='The ferret' pid='274102' dateline='1598644042']
I'm confused too, Ferret.
(08-29-2020, 01:27 AM)Dave_imp Wrote: [quote='The ferret' pid='274102' dateline='1598644042']
Dave I need to install that air funnel kit.
Another question should I use any sealant when install that part https://imgur.com/gallery/ohO2Hre
  Valve Adjustment and Camshaft Removal dave 5 624 03-21-2026, 04:49 PM
  Left side cover removal jeffmazz_imp 24 2,075 07-09-2025, 03:37 PM
Last Post: bflint
  HELP GAUGE REMOVAL /CUSTOM TACH 911jimmy_imp 96 5,889 07-25-2022, 06:54 AM
  Easy bar end weight removal brian10x_imp 6 619 06-06-2022, 01:04 AM
Last Post: 1973cb750
  Fuel Tank Removal Gabby_imp 11 924 06-19-2020, 10:54 AM
  Canister removal Feelergaugephil_imp 2 312 10-11-2019, 10:59 PM
  Handy Cheat Sheet for Maintenance and Wheel removal on my 2017 17-CB-002 12 853 04-17-2019, 12:40 AM
Last Post: ArbitraryThawt_imp
  tire removal jdgrego1_imp 27 1,765 11-15-2018, 07:18 AM
Last Post: jdgrego1_imp
  Heated grips removal Chris potato_imp 7 456 07-26-2018, 11:27 PM
Last Post: itstuantran_imp
  Charcoal canister removal Siggy Javotnik_imp 21 1,313 07-09-2018, 10:22 AM
