CB900 Custom oil stopper on valve head
Hi everybody,
I own a '82 CB900 Custom which I cherish.[/size][/font]
I had to do total strip down of Valve Head recently. Among other things I have seen the "Oil Stopper Plate"s (Part no 12241-425-000) situated on Cam Shaft caps B and C are in bad shape and these small parts are not available any more.
Does any one know the function of "Oil Stopper Plate"s (Part no 12241-425-000) situated on Cam Shaft caps B and C ?
What happens if I omit installing them.
Thanks for your inputs.
Best Regards
A.Orhun
AO this forum is for the modern 2010-2019 Honda CB 1100's but maybe someone will be able to answer your question.
What Ferret said, but hey? Welcome to here nonetheless AOrhun.
(01-25-2021, 02:42 AM)The ferret_imp Wrote: AO this forum is for the modern 2010-2019 Honda CB 1100's but maybe someone will be able to answer your question.
Thanks for clarification I will try other user groups, but may be that `someone` can be found here as well??
PS.. Try older HONDA`s with carburetors seconding your CB1100`s, you may find them more engaging to ride and care for Smile I also own a`86 VF1000 FF.
(01-25-2021, 02:37 AM)AOrhun_imp Wrote: Hi everybody,
Best Regards
A.Orhun
even if in bad shape best to put back in they fit lots of other bikes look on e-bay for a head that may have them
Best Regards
A.Orhun
try davidsilverspares.com
Best Regards
A.Orhun
Best Regards
A.Orhun
Best Regards
A.Orhun
try davidsilverspares.com Thanks for support and advice.
I found Oil Stopper Plate pair at eBay and the Oil Stopper Cap (12242-425-000) at DavidSilverSpares.
Good deal!
AOrhun, glad you were able to solve the problem. When you have the pieces back in the head, would you please attach a picture or two of them in place so that we know where they go and what they do.
The rubber pieces, 12242-425-000 have not been discontinued by Honda. I think the rubber pieces were wedged between the cam bearing caps and the sides of the head to provide a bit of a dam so some oil stays in the right side of the head when the bike is on the sidestand. The 12241-425-000 stopper plates keep the rubber pieces in place.
I do not know what they look like on the CB 900 but the CBX engines had some oil baffles as well.
  Valve Adjustment Shims dave 13 710 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 637 03-21-2026, 04:49 PM
  Valve Adjustment dave 6 869 08-29-2025, 10:46 AM
  Valve Cover Baffle lining ? bflint 6 954 07-26-2025, 11:27 AM
Last Post: bflint
  Valve Adjustment Intervals CBRider_imp 32 3,039 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,558 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
  Observed Valve Clearance Cormanus 16 1,454 03-06-2023, 09:03 AM
Last Post: Tejas_imp
  The OBSERVED Valve Clearance thread Pterodactyl_imp 162 13,285 12-27-2022, 08:35 AM
  Checking valve clearances Maturecheese_imp 74 6,603 12-11-2022, 12:56 PM
  HELP GAUGE REMOVAL /CUSTOM TACH 911jimmy_imp 96 6,316 07-25-2022, 06:54 AM
