Oil filter failure.... Complete loss of oil pressure
x(why)z. I'm really sorry to hear about this. I was with Pterodactyl when it happened to him and it was ugly. So far, it's been a matter of remarkable luck that a serious accident hasn't resulted from these failures.
I'm not keeping score, but this has now been reported on this forum by owners of CB1100s 5 or 6 times; enough for K&N to be paying attention. Someone might help me out: didn't one member say he'd seen reports of this on other forums?
Good luck with your clean up.
+1 for OEM pads. (and get that K&N filter off ASAP....you don't even need to drain the oil).
As for the tires, they should be okay once you clean them with some regular dish soap (Palmolive, etc). It'll take some time but they'll degrease just fine.
Wipe the discs with the soap too, followed by some rubbing alcohol.
It's a crappy story for sure! But I'm glad to hear this didn't result in a dropped bike or injured rider. I hope you can get back at it soon.
Cormanus, maybe this post: http://cb1100forum.com/forum/showthread....#pid156505
There are a LOT of posts on the board about K&N failures. And some nice shots of a Honda filter cut open and the insides shown. Here it is: http://cb1100forum.com/forum/showthread....#pid153789
A simple Google of "K&N filter failure" will give truly alarming supply of incidents.
K&N's warranty info also comes up.
Through all of these stories, I'm sure dozens of people have spoken to K&N about this....and yet these things are still sold??
I spoke to the K&N people last year at the AIMEXPO in Orlando about this problem . (not mine) They should be well aware of this.
I use WIX filters on my bike. This was what I picked up for my oil change supplies a couple of years ago.
(07-24-2017, 07:53 AM)The ferret_imp Wrote: People like the 17 mm nut on the front so they don't need a special oil filter cup. I say buy the cup from your Honda dealer for $10 and have piece of mond
I don't use an oil filter wrench. I had to to get the factory one off, but other than that....I don't need one. I haven't used an oil filter wrench on any of my vehicles other than getting filters off when I first get them in 30 years. I've never had a leak either.
+1 on what Randy said. I always hand tighten.
Always hand tighten, always use a cup to remove, but thats just me lol
Dang it sorry .... thank you for posting.. on the bright side you should not have to worry about anything rusting for a while.I would R&R brake pads... only the rears? Good luck.
You can buy the OEM filter set, which is the filter + the OEM cup, part# 2: https://www.bike-parts-honda.com/pieces-...+1100.html
Not expensive, easy to use with a torque wrench.
  Oil Filter dave 12 557 07-26-2026, 02:33 PM
  Pod Air Filter Traumend_imp 15 1,496 03-06-2024, 08:42 AM
  low oil pressure light Garuda78_imp 16 1,114 02-29-2024, 04:09 PM
Last Post: Garuda78_imp
  CB1100ex Tires pressure, when changed tube to tubeless tory_imp 10 918 10-09-2023, 07:51 AM
  K&N air filter fitment question nikolus_imp 28 3,655 05-20-2023, 09:26 AM
Last Post: Klamathonian_imp
  low oil pressure light kaput norton1974_imp 11 1,069 03-28-2023, 08:58 AM
  Fuel filter replacement Mafd2_imp 36 2,952 02-11-2023, 01:54 AM
  Oil filter won’t come off Jgarciajr40_imp 20 1,637 01-01-2023, 09:38 AM
   Oil Filter Options Yata-Garasu_imp 78 7,500 09-28-2022, 08:03 AM
Last Post: Yata-Garasu_imp
  Air filter options - W/ Part #'s PowerDubs_imp 10 938 09-21-2022, 04:02 AM
