Fuel filter replacement
Has anyone had to change their fuel filter? When should it be changed? I don't think Honda has an interval for it. How hard is it to change?
Rarely if ever changed. Usually would be changed when a new fuel pump assm. is installed as it is part of a new pump. The filter assm. from Honda is $$$$. https://www.partsfish.com/oemparts/a/hon...-fuel-pump item 1
How to do: remove tank, remove fuel pump, remove filter assm. from pump. Install in reverse order.
Welcome to the Forum Mafd2.
That is a good question. It is not something mentioned in recent Honda Owner's Manuals for many models, however, they do indicate inspecting the fuel lines.
This is something covered in shop manuals, but I do not recall a specific interval.
Would anybody have a good picture or two, or is it placed so deep down in the intestines of the m/c that there aren;t any photos possible ?
Gecko, the fuel pump is mounted inside the tank from the bottom. To remove it you have to remove the tank, turn it upside down and unbolt the nuts that hold it. The tank has studs that the nuts thread on to.
Most people are never going to do that. I have as I had to replace my tank. I think I have pics of the pump but can’t find them on the board. They should still be on my phone or Photobucket and I can post them unless someone else posts pics first.
There is no need to ever mess with the filter.
Don't go looking for problems or your likely to make one.
Welcome to the Forum, Mafd2. As my old friend (he's in his mid-nineties and still turning wrenches on Model T Fords) Harold Mann says, "If it ain't broke, don't 'fix' it."
If you happen to remove the fuel tank Gecko, that is a convenient time to inspect and/or replace the fuel filter.
(02-04-2023, 02:46 AM)Nachodaddy_imp Wrote: Welcome to the Forum, Mafd2. As my old friend (he's in his mid-nineties and still turning wrenches on Model T Fords) Harold Mann says, "If it ain't broke, don't 'fix' it."
I somewhat believe in that analogy but,,,, at the same time I like thinking out the box and fix it before it breaks Big Grin
(02-04-2023, 12:46 AM)Lord Popgun_imp Wrote: Gecko, the fuel pump is mounted inside the tank from the bottom. To remove it you have to remove the tank, turn it upside down and unbolt the nuts that hold it. The tank has studs that the nuts thread on to.
I'd like to see pics. Thanks
It won't... again, no need.
You have a much great chance of creating an issue.
Stripped / broken threads, leaking gasket on the fuel line connector or pump tank gasket.
The filter will work fine for the life of the bike.
  Oil Filter dave 12 625 07-26-2026, 02:33 PM
  CB1300 headlight bucket replacement spechg 5 418 03-16-2026, 10:12 AM
  HISS Key replacement UK Davidjill_imp 12 1,082 01-19-2026, 05:09 AM
  Rear brake pad replacement LongRanger_imp 39 4,063 05-03-2025, 10:45 AM
Last Post: Delphisa
  New speed meter replacement ACE_IRA_imp 3 533 02-13-2025, 06:25 AM
  Pod Air Filter Traumend_imp 15 1,573 03-06-2024, 08:42 AM
  Fork Pipe replacement suggestions danieljrmurray_imp 3 537 10-09-2023, 02:31 AM
Last Post: danieljrmurray_imp
  K&N air filter fitment question nikolus_imp 28 3,913 05-20-2023, 09:26 AM
Last Post: Klamathonian_imp
  Replacement Battery dave 54 4,701 02-04-2023, 12:41 PM
  Oil filter won’t come off Jgarciajr40_imp 20 1,777 01-01-2023, 09:38 AM
