low oil pressure light
hello,my first time posting .I have a 2014 cb1100a.
I bought it 2 weeks ago ,with 9000 miles on it..
every thing works great ,however the low oil pressure light does not come on when key is in start pos. i checked the switch on the right side below the engine about 8 inches forward of the rear brake pedal. it has power with key on and off when eng starts.is this the low oil light switch ,or the high oil temp switch i'm looking at??
also, anyone know what color code for the wire that leads to switch.
thank you in advance and its great to be here.
best wishes.
George
Welcome to the forum, Garuda78.
Hey ya! Congratulations and welcome to the Forum Garuda78.
I no longer have schematics, but options include:
1. Bulb (LED) is out or disconnected
2. Wiring is not intact
3. Sensor failed
The warning lights on the lower portion of the speedometer, from left to right, are:
CEL (orange)
Neutral (green)
Hi beam (blue)
Engine oil temp hi (red)
The warning light on the lower portion of the tachometer is
Low oil pressure (red)
Is all wiring to tach fully connected?
This should help with sensor identification:
https://cb1100forum.com/forum/showthread...#pid249673
To my Forum Friends: After putting almost 5,000 miles on my XVS950 in less than 4 months, more eye issues have developed. No double vision (6th nerve palsy of right eye) as occurred in Aug 2018, which compelled me to sell my CB Sep 2018.
An eye exam with cataract diagnosis, left eye correctable to 20/20, but right eye somewhat correctable to only 20/50 sent me to an eye surgeon. Narrow ducts put me at risk for sudden onset of glaucoma and dilation increases eye pressure, so laser surgery for the ducts before Dr can dilate eyes to discuss proceeding with cataract surgery (artificial lenses). So, I may be back to only riding vicariously, although I got in a 433 mile ride to Zion National Park, last Friday.
Dave, Beverly & I look forward to seeing you and Debbie tomorrow afternoon.
If the link above displays weird, remove the s from https: and it will look like normal forum display
(09-26-2022, 09:40 PM)SportsterDoc_imp Wrote: I no longer have schematics, but options include:
3. Sensor failed
CEL (orange)
Neutral (green)
Hi beam (blue)
Clearly the eyes are everything, particularly when it comes to riding. May your way once again be clear. Be patient - even if it costs one riding season.
I plan to be in the Zion National Park in November. It should be exciting.
Doc, hope your eye issues get taken care of!
Welcome and congratulations, Garuda78. Sorry, I can't help with your light issue, but I am sure the others will before long.
Sportster Doc, I wish you well on your eye issues. Having some myself and keep hoping they don't get any worse too soon.
if you didn’t find the EOP switch it is on the right side of the bike, by the lower frame rail, just forward of the big cover that says HONDA on it. It sticks out horizontally.
The neutral switch is just aft of the EOP sensor and sticks straight down.
The EOP wire goes to a 2 pin connector that also has the neutral switch wire.
The EOP wire is Bu/R (blue/red stripe). The neutral wire is light green.
Service troubleshooting is pretty easy.
Check engine oil level first.
Make sure the oil pressure indicator comes on with engin switch ON. Start the engine and the light should go out.
OK, you have no light. So, Remove the EOP sensor dust cover, remove the terminal bolt and disconnect the EOP switch wire.
Ground the EOP switch wire terminal using a jumper. The oil pressure indicator comes on with the ignition switch turned to ON.
It it does not come on, check for a blown sub fuse METER, ILLUMI 10A or an open in the circuit. If the fuse and wire harness are normal, replace the combination meter.
OK, I would not just jump on replacing the combination meter. Do the above and if your problem isn’t fixed, try disconnecting the meter connectors and inspecting the pins and reseating them. Bu/R wire actually goes from the EOP switch all the way to the meter. It goes through the meter 6 pin connector. You can meter it for continuity if you have a meter.
You make it sound so easy Popgun.
Sportsterdoc, best wishes for the eyes.
  CB1100ex Tires pressure, when changed tube to tubeless tory_imp 10 830 10-09-2023, 07:51 AM
  low oil pressure light kaput norton1974_imp 11 971 03-28-2023, 08:58 AM
  Interesting article on tire pressure the Ferret 9 791 11-28-2021, 04:23 AM
Last Post: j3gq_imp
  Cold Weather & Tire Pressure 2017EX_imp 22 1,246 11-28-2019, 08:53 PM
Last Post: Cqrlm911_imp
  Catalytic converter back pressure? ChipBeck_imp 13 878 05-26-2019, 01:42 AM
Last Post: HondaJon_imp
  running light and brake light Ennsync_imp 3 394 01-02-2019, 11:24 PM
  Rear Brake Intermittent Loss of Pressure beardyweirdy@me.com_imp 9 629 11-04-2017, 12:26 AM
Last Post: Dengie Boy_imp
  Tire pressure Sonnyboy_imp 4 406 10-23-2017, 04:51 AM
Last Post: kennyw
  Tire pressure glynb_imp 12 805 09-29-2017, 03:00 AM
  Oil filter failure.... Complete loss of oil pressure x(why)z_imp 49 2,852 09-14-2017, 10:12 PM
Last Post: paulw_imp
