low oil pressure light kaput
hello.my 2014 cb1100 low oil pressure red light does not light.
ground from switch to gauge checks fine.
i have illumination for both gauges,
does the gauge light and the low op light use the same hot lead?
if not which color wire supplys the power for light.
the ign wire black/brown is my guess
thank you for your help
norton1974, you may find some help here ... http://cb1100forum.com/forum/showthread....#pid217528
That is my understanding as well, 1974.
The lights used for oil pressure etc. are led's, they last forever which is why they are so suitable for this job.
Led's run on 3 volts and so need a resistor in series to run on higher voltages.
Could be there is a bad soldering joint inside the cluster which prevents the led from operating,
and a link to a german video with a 2013 instrument cluster, this is not your type but it may give you an idea what to expect for the repair;
And how it's put together;
https://www.partsfish.com/oemparts/a/hon...5a33/meter
Have you checked that the oil switch opens with the engine running and the blue led lights up with the high beam?
If the led is no good I can replace that I have experience soldering smd LEDs on gauge clusters pm me if you find that is the issue
also leds do not last forever especial poorly manufactured leds witch are about all you can get now days
(03-27-2023, 12:40 AM)1973cb750_imp Wrote: also leds do not last forever especial poorly manufactured leds witch are about all you can get now days
More often than not, LED "failure" is due to poor power supply characteristics, that is, the power circuitry is problematic and the LED is fine.
More often than not, LED "failure" is due to poor power supply characteristics, that is, the power circuitry is problematic and the LED is fine. that is true but lately since the "chip" shortage i have seen alot of failures even in high end equipment
Hopefully the world can flush and turn that nonsense around.
One more thing; what is the volt meter reading between the DISCONNECTED oil pressure switch wire and ground with the ignition switch in run?
(03-27-2023, 01:09 PM)max_imp Wrote: One more thing; what is the volt meter reading between the DISCONNECTED oil pressure switch wire and ground with the ignition switch in run?
i've always checked those with continuity cb doesn't use a ground interrupted switch for the dummy light ?
  low oil pressure light Garuda78_imp 16 1,086 02-29-2024, 04:09 PM
Last Post: Garuda78_imp
  CB1100ex Tires pressure, when changed tube to tubeless tory_imp 10 879 10-09-2023, 07:51 AM
  Interesting article on tire pressure the Ferret 9 805 11-28-2021, 04:23 AM
Last Post: j3gq_imp
  Cold Weather & Tire Pressure 2017EX_imp 22 1,310 11-28-2019, 08:53 PM
Last Post: Cqrlm911_imp
  Catalytic converter back pressure? ChipBeck_imp 13 910 05-26-2019, 01:42 AM
Last Post: HondaJon_imp
  running light and brake light Ennsync_imp 3 423 01-02-2019, 11:24 PM
  Rear Brake Intermittent Loss of Pressure beardyweirdy@me.com_imp 9 644 11-04-2017, 12:26 AM
Last Post: Dengie Boy_imp
  Tire pressure Sonnyboy_imp 4 427 10-23-2017, 04:51 AM
Last Post: kennyw
  Tire pressure glynb_imp 12 842 09-29-2017, 03:00 AM
  Oil filter failure.... Complete loss of oil pressure x(why)z_imp 49 2,881 09-14-2017, 10:12 PM
Last Post: paulw_imp
