Oil filter won’t come off
Trying to do my first oil change since buying my CB.
Oil filter almost feels wielded on. I used my channel lock oil wrench all that did was was crush it. I tried a 65MM oil wrench I have but I think it’s a 64MM filter? It slides off, and I tried stabbing it with a screw driver and turning all I did was break my screw driver…
Any ideas how I can get this filter off? I was thinking of one of those rubberband ratcheting wrenches but I can only find car ones that are too big…
Yikes! I've used a rubber band ratcheting wrench with no problems. There's been a fair bit of the band left over. Otherwise you may have to buy a metal circular wrench or the special Honda filter removal tool.
I wish I had some help for you, but this one's a real head-scratcher. Hope it turns out well for you. If it were me, I'd probably be in there with my Dremel tool taking it out piece-by-piece. Not a solution I recommend, however.
Hammer and chisel near the base, counterclockwise. BE CAREFUL NOT TO HIT THE ENGINE CASE!
Sent from my Pixel 6 using Tapatalk
Since you tried a screwdriver and broke it, I would try again with another screwdriver that won't break. ¯\(⊙ʖ⊙)_/¯
Mine was the same when I bought my bike earlier this year. I'm almost certain it was the original filter since the bike only had 2600 miles on it.
I used a chisel and hammer. Just be careful and take it slow. Don't be an animal!!....lol
NAPA has a band socket that requires a 1/2 inch drive. I had the same problem with the filter on a Kawasaki Mule. I had destroyed the filter trying the same techniques. The Napa tool and a breaker bar got it off easily. It's a socket with a web band attached that winds around the socket shaft and gets tighter as force is applied to the breaker bar or socket wrench.
I got it off spraying the seal of the filter with WD-40 and attacking it again with my channel lock oil filter wrench.
I bought one of those ratcheting filter wrenches didn’t help at all - channel lock did the trick.
Guys quick question; when do you check the oil level? My work truck the level must always be checked cold. I put in a gallon and before starting the bike it said I was overfilled. I started the bike let it run for 2-3mins and turned it off now I’m maybe a hairline above the lower sight glass line.
Figure I need to go get a bottle tomorrow and add cup or two more?
If the filter canister is maximally mangled at this point, use an ol' slap joint plier to twist it off. Bob's yer uncle.
Okay now my oil level is perfectly in the middle?
  Oil Filter dave 12 542 07-26-2026, 02:33 PM
  Pod Air Filter Traumend_imp 15 1,460 03-06-2024, 08:42 AM
  K&N air filter fitment question nikolus_imp 28 3,450 05-20-2023, 09:26 AM
Last Post: Klamathonian_imp
  Fuel filter replacement Mafd2_imp 36 2,830 02-11-2023, 01:54 AM
   Oil Filter Options Yata-Garasu_imp 78 7,290 09-28-2022, 08:03 AM
Last Post: Yata-Garasu_imp
  Air filter options - W/ Part #'s PowerDubs_imp 10 900 09-21-2022, 04:02 AM
  Video: oil and filter change Scotty_imp 15 1,166 12-05-2021, 02:43 AM
  Air Filter Change Interval? dave 25 1,874 11-09-2021, 02:18 AM
Last Post: SportsterDoc
  Oil change - filter differences. Mixagon_imp 41 3,212 09-07-2021, 07:44 AM
  2018 air filter Rogerdj_imp 4 433 08-20-2021, 08:29 AM
