CB1100ex Tires pressure, when changed tube to tubeless
Tires pressure front 36 psi rare 42 psi use the same or not?
Thanks
36 front; 42 rear. See the manual here: https://cdn.powersports.honda.com/docume...cb1100.pdf
Thanks
But, i want to try 40 on rear.
Sure.
tire pressures are recommendations, the needs for which vary due to rider weight, if they have a passenger, if they have luggage etc. The more weight on the bike the more tire pressure is needed.
I generally run 38 front 40 rear on my bikes, solo rider, 185 pounds, no luggage. If I take a trip and throw some luggage on the back I bump the rear to 42.
And remember tire pressure is only as accurate as the gauge used to measure it.
(10-09-2023, 02:20 AM)The ferret_imp Wrote: tire pressures are recommendations, the needs for which vary due to rider weight, if they have a passenger, if they have luggage etc. The more weight on the bike the more tire pressure is needed.
lol - the exact same over-thought tire pressure topic (yet, again Dodgy ) is happening at the Honda Africa Twin Forum site.
There are probably multiple threads on it on every forum Wink
Did someone mention oil? Cool
ROFL
(10-09-2023, 06:02 AM)Cormanus_imp Wrote: Did someone mention oil? Cool
... that fruit is just toooo low hangin', Cormanus.
  2017 Honda CB1100EX modifications kennyw 28 2,058 05-09-2024, 09:26 AM
Last Post: FlipModeOne_imp
  low oil pressure light Garuda78_imp 16 1,072 02-29-2024, 04:09 PM
Last Post: Garuda78_imp
  Question re: 2017EX spoke rims tubeless conversion slmjim n Z1BEBE_imp 6 525 10-28-2023, 09:24 PM
Last Post: slmjim n Z1BEBE_imp
  2017 CB1100EX Accessory Plugs TXBikerGuy 13 1,116 06-24-2023, 08:27 AM
  2018 CB1100EX just collected from service Motorsport3_imp 5 547 05-10-2023, 11:25 PM
Last Post: Motorsport3_imp
  low oil pressure light kaput norton1974_imp 11 974 03-28-2023, 08:58 AM
  2017 tube type tires Mafd2_imp 4 473 02-08-2023, 01:10 PM
  Fork tube rust melfl_imp 8 730 12-23-2022, 04:41 AM
Last Post: redbirds_imp
  2017 CB1100EX Brake Bleeding M1tch_imp 1 293 03-05-2022, 04:29 PM
  Interesting article on tire pressure the Ferret 9 791 11-28-2021, 04:23 AM
Last Post: j3gq_imp
