HELP GAUGE REMOVAL /CUSTOM TACH
Man, the research guys never get any credit Big Grin
Just so you know I’ve got test equipment hooked up to my bike right now while we work the hi/lo idle issue. So there. Excited
You research and technical guys amaze me, totally amaze me. Glad we have a few of you smart types around here. Worship
ROFL
I hear ya pop. Kudos to you too! This forum is just great. The regulars here seem like great folks. Kudos to all of you. If I wasn't 2 mos from being a first time father I would seriously consider the Kentucky trip to shake some hands.
Keep up the good work!
Fatherhood is a pretty good excuse, Bheezy. Very best wishes to you and your partner and the new baby.
By the way, I'm no expert on headlight buckets. There's a whole lot of wires and stuff in there and I wouldn't really want to have to try to make sense of them, but it's not too bad to put it all back together. The worst thing about it is figuring how to get the connectors to pop open without them breaking. They look simple but never seem to open quite the way I expect.
(02-13-2018, 12:52 PM)Bheezy27403_imp Wrote: Agreed that popgun helped as well but he just pressed a few buttons. You sir went above and beyond and turned a wrench or two. I would rather go to the dentist then get in the headlight bucket. I've never been in the CB's but if it is like any other bike I've had (can't imagine it's not) it's no fun.
Don't down play it. A random clown joins the forum to ask a rather strange question and you drop everything and help him out. Thumbs Up
No offense to the "random clown". Big Grin
You will be in it soon enough when the headlight burns out! The vibes get to them. Truly, not to take anything away from the altruistic nature of the forum, but it's not that bad at all. Couple of screws if I recall.
Okay guys it sounds like you've done so much amazing work thank you so much!!
I just want to clarify a few things for those who were wondering, the motorcycle was crashed really hard on a Canyon Road, it's near $6,000 in parts later to get to this point and the gauges were destroyed ..
The original owner unfortunately threw the gauge pieces away otherwise I would have totally left that part plugged in and had it hidden under the seat.
As you can see in the photo none of that stuff exist anymore and min of $1000 more just for the stock gauges which are too bulky for the custom motodemic headlight setup..
[Image: 0327dfb8d00e426108950e5bd2385e8d.jpg?dl=0]
[Image: e8d70ee9ef3113789d1766ad7685b70c.jpg?dl=0]
THANK YOU CORMANUS & POP
I BELIEVE CORMANUS ANSWERED THE QUESTION, AND ITS GOOD NEWS !! THE 2013 BIKE WILL RUN WITHOuT THE GAUGE ..
SO NEXT STEP IS GETTING THE 2013 WIRING AND ECU AND WE SHOULD BE ABLE TO GET IT GOING ..
*POP*
ALSO WANTED TO NOTE THE KOSO GAUGE HAS ITS OWN SPEED SENSOR & WIRING THAT WEVE INSTALLED ON THE FRONT BRAKES INDEPENDENT OF ECU
I WILL UPDATE AS THIS GETS DONE AND FIGURE OUT HOW TO POST THE BETTER PICTURES , BECAUSE THE BIKE CAME OUT SO NICE ...
Jimmy, create an Imgur account, post your pictures there and then link to them here. Sing out if you need help.
Bike looks good.
Good luck.
(02-13-2018, 02:34 PM)911jimmy_imp Wrote: Okay guys it sounds like you've done so much amazing work thank you so much!!
*POP*
NOT so fast..
As popgun & others already mentioned 2013 2014 wiring harness is different = for sure !!
Swapping partial harness with ECU ( if it comes in few separatable sections) may not work.
Also Ulvetanna is correct with his statement:
"If you were to tear apart the gage housing, you would find computer circuitry needed to process the bike's data critical to operation.
If you were really clever you could remove only the circuit boards needed, put them into a small, separate housing, and locate that inconspicuously somewhere, like, under the seat. Run the CANBUS line to it and connect everything exactly the same as if it were the gage cluster.
The mechanical gages don't need to be connected, but, who knows how they've been integrated into the circuitry? The whole thing may be nearly impossible."
You may also have an issue with a VIN reading or writing after swapping..???
Now days with the electronics, ECU, VIN, CAN+++ it becomes very difficult if not impossible to interchange/swap parts from other vehicles. Manufactures do not want anybody to buy parts from aftermarket or wreckers, only OEM, they mean business.
Your project needs deeper study prior spending money with no results..!!
Be aware what you digging into, and I doubt if anybody can clearly say "yes , it's gonna work"
pb
*POP*
NOT so fast..
pb
NOT so fast..
pb \
THANKFULLY THESE BIKES DON'T HAVE ANYTHING LIKE THAT.... ONLY ONES THAT I KNOW OF THAT HAVE SUCH ISSUES ARE ITALIAN BIKES LIKE DUCATI, APRILIA.... HONDA HASNT COME THAT FAR YET, WE CAN MODIFY THE HARNESS IF NEED BE OR WE HAVE NO PROBLEM GETTING WHATEVER IS NEEDED FROM THE 13 INCLUDING THE ENTIRE HARNESS.
WILL UPDATE WITH IMAGES.
*POP*
NOT so fast..
pb
NOT so fast..
pb \
Good luck Thumbs Up
pb
  Valve Adjustment and Camshaft Removal dave 5 636 03-21-2026, 04:49 PM
  Left side cover removal jeffmazz_imp 24 2,199 07-09-2025, 03:37 PM
Last Post: bflint
   Digital tach shorting out kentf1120_imp 1 256 03-16-2023, 09:33 AM
  Clock Speedo and Tach died while riding adogsnyder99_imp 2 357 06-15-2022, 01:00 AM
Last Post: 17-CB-002
  Easy bar end weight removal brian10x_imp 6 625 06-06-2022, 01:04 AM
Last Post: 1973cb750
  Fuel gauge flashing from center outward.... mattmcuomo@yahoo.com 29 2,445 06-02-2022, 03:13 AM
Last Post: thomas_imp
  Explanation of 2014 Fuel Gauge the Ferret 28 2,054 04-27-2022, 01:46 PM
Last Post: ChiefJP_imp
  CB 900C Custom Spark Issue goatman64_imp 3 383 11-27-2021, 07:11 AM
  CB900 Custom oil stopper on valve head AOrhun_imp 9 820 01-27-2021, 10:06 PM
  Air box removal ACE_IRA_imp 23 1,703 09-25-2020, 05:56 AM
Last Post: ACE_IRA_imp
