Easy Way to do a Headlight Mod?
Why not just have the LED running lights on all the time when the ignition is switched on? You could do this by putting a relay in that was triggered by current from a wire that is energized when the ignition switch is on. The relay would complete a circuit from the battery to the LED running lights. Or you could use a fuzeblock that has a bank of circuits that are alive when the ignition is on. Then you could put a switch on your low beam headlight power wire to turn it on or off. The LED running lights are on anytime the ignition is on, whether hi beam, low beam or no beam. That should be OK since they are running lights, and because they are low draw LEDs the additional current draw should not be a problem when the bike is running. They would go out when you switch off your ignition, but if you are switching it off at a stoplight, you would switch it back on right away, so that you could just hit the starter button when you want take off again.
If you really only want them on if you switch your low beam off, you can get a relay that completes a circuit when power is NOT supplied to the triggering terminal of the relay. Usually these relays have 2 outputs, one that is complete when the trigger is on, one that is complete when the trigger is off. So, put you switch in the low beam circuit, add the wire to the relay trigger AFTER the switch and when you switch your low beam off, no current hits the relay trigger and the normally closed circuit of the relay is no longer being held open, so it closes and your LEDs have power.
Another way to do this would be a double throw switch. when switched one way, the current output would go from the center terminal to the left (A) terminal, flipped the other way, the current would go from the center terminal to the right (B) terminal. The problem will be locating a weatherproof double throw switch.
Actually that kind of gives me an idea:
How difficult would it be to have the headlight go on and off with a stator charge? In other words...if the engine is stalled, the headlight (not all lights, just the headlight) would go out?
A headlight relay, sure. What to wire it to?
  Headlight shell Lord Popgun 11 1,499 10-08-2025, 01:17 PM
  2017 MY CB headlight upgrade. 17-CB-002 16 2,195 09-06-2025, 05:00 PM
  auxiliary 12v in headlight shell Maturecheese_imp 6 592 03-25-2023, 07:14 AM
  Delay when using headlight switch? Jgarciajr40_imp 15 1,045 12-05-2022, 07:11 AM
Last Post: max
  Headlight shell acc connector HBFL_imp 2 324 08-28-2022, 08:18 PM
Last Post: HBFL_imp
  headlight adapter j3gq_imp 15 1,091 07-18-2022, 04:12 AM
Last Post: max
  Easy bar end weight removal brian10x_imp 6 606 06-06-2022, 01:04 AM
Last Post: 1973cb750
  Easy RLET installation, using a sheep castrator willsmith_imp 60 4,233 02-03-2022, 06:26 PM
Last Post: Bazbro_imp
  Melted headlight Lord Popgun 6 556 05-23-2021, 03:59 PM
Last Post: LikeAfox_imp
  Headlight bulbs Randy B 80 5,787 05-17-2021, 01:42 AM
Last Post: Zee9_imp
