auxiliary 12v in headlight shell
This has been covered on this forum elsewhere so I'm not looking for advice on how to do it just where I can get the other half of this connector in the UK. I'll paste and copy my FB post to save typing it out again
see here
http://cb1100forum.com/forum/showthread....=connector
Going to fit a USB charger to my bike but what a palaver. I want to use the 12v ignition circuit supply in the headlight rather than run it to the battery but Honda do not supply a live plug to their blanking auxiliary 12v supply in the headlight casing. Oh no they expect you to but a £137 kit, yes really!
Obviously i can just buy a waterproof plug for £2 odd from amazon but it means cutting the current half a plug off and fitting a new one with around an inch of cable to play with in an awkward place. I will probably have to pull the loom out of the headlight shell to fit the new plug.
In the old days I would have just cut the plug off and twisted the wires together Smile
https://www.ebay.co.uk/itm/403723009764?...R87bopDjYQ
i ebayed hm 90 series on ebay uk
I got switched 12v inside my headlight to run LED lights and didn’t buy anything to do it. Would have been a few years ago so can’t remember exactly how, but I did…
(03-24-2023, 11:46 PM)1973cb750_imp Wrote: https://www.ebay.co.uk/itm/403723009764?...R87bopDjYQ
Thank you would this one work it was at the bottom on the link you put up, I believe it will
https://www.ebay.co.uk/itm/184497918351?...6041873059
I wired heated grips into the headlight connector using Positaps and it was a piece of cake: https://a.co/d/ca9Eu9W
Sent from my Pixel 6a using Tapatalk
Should work I believe
I will try to look later. Lord Popgun has previously identified the connector and where to get it.
UPDATE: Townie was the man, http://cb1100forum.com/forum/showthread....#pid102371
  Headlight shell Lord Popgun 11 1,510 10-08-2025, 01:17 PM
  2017 MY CB headlight upgrade. 17-CB-002 16 2,214 09-06-2025, 05:00 PM
  Delay when using headlight switch? Jgarciajr40_imp 15 1,061 12-05-2022, 07:11 AM
Last Post: max
  Headlight shell acc connector HBFL_imp 2 330 08-28-2022, 08:18 PM
Last Post: HBFL_imp
  headlight adapter j3gq_imp 15 1,123 07-18-2022, 04:12 AM
Last Post: max
  Melted headlight Lord Popgun 6 571 05-23-2021, 03:59 PM
Last Post: LikeAfox_imp
  Headlight bulbs Randy B 80 5,876 05-17-2021, 01:42 AM
Last Post: Zee9_imp
  Headlight malfunctioning Ernie_imp 11 885 12-31-2020, 04:50 AM
Last Post: max
  headlight not compatible? GroovyBunny86_imp 11 884 12-06-2020, 10:49 PM
  Headlight is absolute junk! FLYTYM_imp 23 1,500 06-24-2019, 06:07 PM
Last Post: FLYTYM_imp
