Likes Given: 142
Has anyone seen this problem?
[url=https://app.photobucket.com/u/everettmclendon/a/a8b5b03b-ad65-49a1-a3d0-f45df1fc2c20/p/a65ed968-06ce-4f37-bfa5-6554b0a8172c]
It is melted on the inside. Is dished in some on the outside with cracks radiating out from the dished melted area you can see and feel with a fingernail.
My guess is when parked in the sun, light was reflected from the reflector and melted it. Other theories are welcome.
Threads: 18
Likes Received: 2 in 1 posts
(05-23-2021, 12:21 AM)Lord Popgun_imp Wrote: Has anyone seen this problem?
[url=https://app.photobucket.com/u/everettmclendon/a/a8b5b03b-ad65-49a1-a3d0-f45df1fc2c20/p/a65ed968-06ce-4f37-bfa5-6554b0a8172c]![[Image: e327cdcf41e5405c121c2d488b7cbfd6.HEIC]](https://cb1100forum.net/forum/uploads/imp/202105/e327cdcf41e5405c121c2d488b7cbfd6.HEIC)
The sun reflector idea makes sense to me. Ive used solar ovens when backpacking. They get HOT
Threads: 41
Likes Given: 39
I've seen this happen on the outside lens when a bike is left idling for a long time and a jacket or cover is draped over the light. Could also be sun reflection, since sportbike windshields have been known to melt gauges.
I'll buy into the sun concentrator theory.
Threads: 39
Likes Received: 15 in 8 posts
Figuring that if it happened once it can happen again i took a transparent piece of paper ( a receipt in this case ) held it over the top part of the headlight and with a torch held at the same angle the sun would illuminate the headlight and aiming at the bottom half of the headlight i could produce a blob in the area that the spot is shown.
Initially i entertained the theory that the co2 content was higher in the headlamp
but i just could not prove that so i'll stick with Lord Popgun's et all findings
Threads: 245
Likes Received: 1,204 in 517 posts
Likes Given: 975
On my 2007 R1200R, I put some clear cling vinyl over the lens to prevent stone chips. Within a few months, similar cracks developed. I figure my effort to protect the lens created too much heat trapped in the plastic.
Threads: 3
That's pretty wild. need to get a headlight visor, old school style
