Headlight shell
The plastic headlight shell, or bucket, on my bike has developed stress cracks at the mounting bosses (where it mounts to the mounting brackets or ears as some call them.
They were hard to see.  I found them by chance when looking around with a flashlight.  The right side has 2 and the left side has 1.  They are an inch or so long.
They originate at the bolt hole.  And yes the metal inserts are installed.  I have a Road Comet installed so maybe that had something to do with it.
I did epoxy them on the inside.
Can you guys take a look and see if anyone else has them?
Holder of the CB1100forum Secret Decoder Ring
2012 ST1300
2013 CB1100
I find your lack of RLETs disturbing
There's none on mine that I can see with a flashlight Mi Lord, but I have a painted aftermarket bucket on mine (11 years old, 78,000 mi)
No cracks on mine. Thanks for the heads-up!
No cracks on mine.
You might consider synchronizing your RLETS to alleviate high frequency vibrations that is being transmitted to your fork ears.
In my stable:
2014 Honda CB1100 Standard
1967 Honda CB77 Superhawk
Hummm, might have to do the RLET sync Smile
Actually I have been hearing a vibration at 2k or so RPM since I installed the Road Comet for the Summer and couldn’t figure it out. Holding onto the RC would make it stop. Investigation lead to finding the shell cracks.
I haven’t ridden it this week due to weather. So, this evening I inspected the headlight sub frame (or whatever it is called) and noticed the RC was against he headlight in one spot. After adjusting the headlight down some and remounting the RC—no contact. I’m hoping that stops the buzz.
Thanks guys for checking yours. That helped. Now I have to have a talk with the RLETs…
I’ll let you know how it goes after I can ride again.
2012 ST1300
2013 CB1100
Check if any RLET is cracked.. if it is, you have an imbalance issue!
           "Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan®
            *Grand Chancellor*
RLETs checked and are good. I have to say PB, the Ring wasn’t any help. Could have warned me…
After some more inspection, The bottom of the headlight trim ring was contacting the Road Comet. Was hard to tell. I moved the headlight down a tad and closely checked all clearances and all was good. Test ride was next and all buzzing was gone.
Hopefully the light is adjusted OK. I never ride at night so I’ll worry about that later.
Yesterday the turn signal switch started sticking some so today I’ll address that.
2012 ST1300
2013 CB1100
MiLord, you are very lucky to be the owner of the Ring, every other member has to diagnose everything step by step and himself ... Wink
            *Grand Chancellor*
So, apparently, does Lord Popgun now. I knew always something sus there was about that ring.  Dodgy
Actually ya know, it has a mind of its own. And it likes to laugh at dumb user induced faults. Smile
2012 ST1300
2013 CB1100
  2017 MY CB headlight upgrade. 17-CB-002 16 2,269 09-06-2025, 05:00 PM
  auxiliary 12v in headlight shell Maturecheese_imp 6 646 03-25-2023, 07:14 AM
  Delay when using headlight switch? Jgarciajr40_imp 15 1,117 12-05-2022, 07:11 AM
Last Post: max
  Headlight shell acc connector HBFL_imp 2 338 08-28-2022, 08:18 PM
Last Post: HBFL_imp
  headlight adapter j3gq_imp 15 1,160 07-18-2022, 04:12 AM
Last Post: max
  Melted headlight Lord Popgun 6 592 05-23-2021, 03:59 PM
Last Post: LikeAfox_imp
  Headlight bulbs Randy B 80 6,016 05-17-2021, 01:42 AM
Last Post: Zee9_imp
  Headlight malfunctioning Ernie_imp 11 890 12-31-2020, 04:50 AM
Last Post: max
  headlight not compatible? GroovyBunny86_imp 11 896 12-06-2020, 10:49 PM
  Headlight is absolute junk! FLYTYM_imp 23 1,545 06-24-2019, 06:07 PM
Last Post: FLYTYM_imp
