2017 MY CB headlight upgrade.
Good Day,
Most owners of 2017 Cb already knows that the LED headlight performance is not up to par.
So I am thinking of replacing the headlight "glass" unit on my 2017 CB with a projector LED type.
I did a quick measurement and I am not 100% sure on the exact measurement of the "glass", it roughly measured between 6.5" to 7.0".
I did not remove the chrome bezel, so my measurement is not that accurate.
I am in process of analyzing the weird headlight wiring set-up (8-wires) and confirm where I can tap into the original harness.
Anyone knows the exact diameter of the headlight glass?
Any help is appreciated.
Alain, didn't we already go through this a long while ago...???
[Image: YZckKbC.jpg]
[Image: W7dVewj.jpg]^^THIS^^ is your hand written diagram.....and some of my notes...
....and this one bellow is a German or Austrian member and my hand notes...
[Image: Bn1fIvN.jpg]
..and these bellow are my hard copy notes..
[Image: MwwSCpy.jpg]
[Image: wWsWukx.jpg]
As far as I nremember this project has never been materialized, correct???
           "Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan®
            *Grand Chancellor*
(08-27-2025, 06:17 PM)peterbaron Wrote: Alain, didn't we already go through this a long while ago...???
No I did not do the modification - too chicken to splice through the original factory wiring
This time I will go through (after some nighttime riding).
I didn't know a headlight wiring could be so complicated! I'm used to the three-wire connections: One wire for the ground, one wire for low beam, and one wire for high beam.
Really like your new avatar Peter, very nice.
Update is coming soon
            *Grand Chancellor*
Many 2017 EX owners have complained about the standard LED bulb performance, including myself.  It has gaping holes in the low beam pattern, and not seemingly very bright except on high beam, absolutely the worst light I can recall.  The H4 lights on the 2013-2014 are far superior as far as a wide pattern with no holes - not LED brightness, but safer overall.
I've looked at retro-fitting the 2013-2014 light to my 2017, but there are problems.  The headlight shell only takes the standard headlight rim that is common to all 3 years of US market CB1100s.  They have integral mounting pivots and beam adjuster, so there is no way to mount any other reflector/beam setup.
Because comparable LEDs use around 1/4 -1/3 the amperage, the circuit's wiring is much smaller gauge, maybe a 22-24 gauge.  Low beam is on all the time, and the starter switch no longer needs to cut out the headlight when cranking.  High beam is on a separate fused 10 amp circuit.
If I were to revert to an H4 bulb, I would be inclined to use a headlight relay.  Or I could install an aftermarket LED replacement for the H4, but they have their own  quirks, needing heat sinks or cooling fans, or a modulator box.  There are NO brand name LEDs.  I'll still keep trying to pursue this avenue.
Copy that.
2017 Honda CB1100 EX
(09-02-2025, 06:36 PM)pekingduck Wrote: Many 2017 EX owners have complained about the standard LED bulb performance, .......
If I were to revert to an H4 bulb, I would be inclined to use a headlight relay.  ........
Absolutely!
            *Grand Chancellor*
One of my reservations about an LED/H4 conversion was the quality of bulbs available - too many unknown/untested companies.  But I did find 2 from reputable companies - Phillips and Hella.  Both have self-contained drivers and integral cooling fans and 19-20 watts of power draw.  Both about $50 a pair.  Might throw the other one in the Ducati.
Attached Files Thumbnail(s)
  LITHIUM BATTERY UPGRADE: Ballistic vs. Antigravity vs. Shorai E11even_Hunnit 15 1,451 02-25-2026, 11:06 PM
Last Post: Sadorphan
  Headlight shell Lord Popgun 11 1,520 10-08-2025, 01:17 PM
  CB1100 fuel tank upgrade johnnyH_imp 3 443 03-13-2024, 01:31 AM
  auxiliary 12v in headlight shell Maturecheese_imp 6 622 03-25-2023, 07:14 AM
  Delay when using headlight switch? Jgarciajr40_imp 15 1,082 12-05-2022, 07:11 AM
Last Post: max
   2017 EX Headlight Dimmer Switch problem? sleeper_imp 24 1,810 10-08-2022, 12:27 PM
  Headlight shell acc connector HBFL_imp 2 336 08-28-2022, 08:18 PM
Last Post: HBFL_imp
  headlight adapter j3gq_imp 15 1,138 07-18-2022, 04:12 AM
Last Post: max
  Melted headlight Lord Popgun 6 584 05-23-2021, 03:59 PM
Last Post: LikeAfox_imp
  Headlight bulbs Randy B 80 5,911 05-17-2021, 01:42 AM
Last Post: Zee9_imp
