Idel speed
Is this the service manual one for our CB1100?
61MGC00
It looks like it.
It 's for a CB1100A, I gather ABS brakes.
In Austalia It's CB1100F. Non ABS.
The manual we get in the US covers both ABS and NON ABS bikes.
I believe the part number is in the owners manual, but your dealer can get it for you if not.
I looked on Helm and 61MGC00 is the manual for our bikes, and shows it is for CB1100/A, both ABS and non-abs
my CB idles at 1k.. I found this thread because that seems high, so I was looking for a solution. but I guess it isn't high at all..
Enzo. Was your bike initially idling at a lower RPM, and does it now appear to be idling higher? Check-out the link on this forum titled "15' CB1100 Idle speed unstable problem". My bike experienced symptoms of too low (stalling) and too high (1,400 - 1,500 RPM) both. There are several people on this forum who have experienced problems with varying idle speed. The most common was with idling too low and stalling, but there are reports of it going both ways. One member reported that the dealer told him the throttle cable was improperly adjusted. Some members have had their entire throttle body assembly replaced. I believe that this is a fairly common problem, and some bikes exhibit it to a larger degree than others. On my bike the problem came and went, and right now (I cross my fingers and pray) it is idling nicely at (approximately) 1,050 RPM. Good luck, and let us know if your idle RPM fluctuates in the future.
When I had the stalling problem occasionally it would also seem to 'stick' at a higher than normal idle speed.
Since the stalling issue is fixed by the dealer under warranty (replaced full throttle body) my bike tends to high idle from time to time.
Speaking of 1200-1300 max.
After experiencing the annoying and potential dangerous stalling problem, I can live with a bike that idles slightly higher than normal. Smile
But most of the time the idle speed is spot on btw.
  CB1100 Idle speed instability problem ericlo69_imp 1,434 120,101 07-26-2026, 01:51 AM
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 896 10-22-2025, 02:11 PM
  Install a 6-speed trans on a 2013? amacbeth_imp 37 3,325 02-21-2023, 12:22 PM
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,445 06-03-2022, 01:16 PM
  Speed bleeders Raceman_imp 21 1,612 12-14-2021, 04:30 AM
  speed sensor output Lord Popgun 16 1,149 10-09-2020, 09:20 AM
  5 Speed, extra tooth Rogerdj_imp 2 331 09-12-2020, 08:01 PM
  RE: CB1100 Idle speed instability problem Lambchops_imp 52 3,668 07-09-2020, 08:06 AM
Last Post: SportsterDoc
  Bike surging at speed dsan1964_imp 13 987 07-05-2020, 02:45 AM
