Speed bleeders
Installed Speed Bleeders f&r and clutch pn 8125l on 14 Deluxe this morning. This is my first experience with speed bleeders. They really do work well. Clutch fluid was dark, obviously had never been changed.
I need to get those things for both my bikes.
I did put them on all my CB 1100's , easy to do and a cheap upgrade , use the stainless steel ones if you do the change .
They are excellent. I've installed them on two of my bikes, like Houtman I went with the stainless steel versions.
These interest me so clue me in guys.
What brand and size (mm) are they?
Go to Speed Bleeder Products Inc.
They are SBB125 -SS M8 1.25
They are available in different lengths and for my clutch on my bikes I bought a slightly longer one.
(07-06-2021, 10:57 PM)Houtman_imp Wrote: Go to Speed Bleeder Products Inc.
Thanks a bunch. Appreciate the info Thumbs Up Thumbs Up
(07-06-2021, 03:13 AM)Raceman_imp Wrote: Installed Speed Bleeders f&r and clutch pn 8125l on 14 Deluxe this morning. This is my first experience with speed bleeders. They really do work well. Clutch fluid was dark, obviously had never been changed.
Did you order the SB8125L-SS? I see that the CB1100 isn't listed, but rather they list the SB8125L for Nissin calipers. And SS appears to denote the stainless steel version. Is that the same part for the clutch as well?
I used the 8125l for calipers and clutch. I called Speed Bleeders and a agent provided me with the correct parts.
I'm guessing you replace the oem bleed screw and leave the new ones on.
For anyone who has installed these on the clutch bleeder, is there enough clearance for the SB8125L or LL once the cover is back on?
  CB1100 Idle speed instability problem ericlo69_imp 1,434 119,047 07-26-2026, 01:51 AM
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 883 10-22-2025, 02:11 PM
  New speed meter replacement ACE_IRA_imp 3 527 02-13-2025, 06:25 AM
  Install a 6-speed trans on a 2013? amacbeth_imp 37 3,297 02-21-2023, 12:22 PM
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,429 06-03-2022, 01:16 PM
  speed sensor output Lord Popgun 16 1,130 10-09-2020, 09:20 AM
  5 Speed, extra tooth Rogerdj_imp 2 329 09-12-2020, 08:01 PM
  RE: CB1100 Idle speed instability problem Lambchops_imp 52 3,608 07-09-2020, 08:06 AM
Last Post: SportsterDoc
  Bike surging at speed dsan1964_imp 13 961 07-05-2020, 02:45 AM
  Looking for a Speed bleeder P/N for Clutch Slave Cylinder venturer434_imp 6 940 10-14-2017, 09:01 PM
Last Post: venturer434_imp
