Idel speed
Hi people of good taste......
My steed seems to be Idling a bit high.
Is it a screw driver adjustment or is a trip to a meck.
Thanks
enzo
(08-23-2013, 02:04 PM)enzo_imp Wrote: Hi people of good taste......
Thanks
enzo
how high is high?
1.2 to 1.4
That's at riding temp.
1.4 mine will run that as it warms up, 1.2 is in spec at 1.1 +_ .1 if memory serves me. There is no idle adjustment screw
There is no screw for idle adjustment. If you have a service manual, look on page 3-16. A number of systems can cause the engine to idle incorrectly. If all else is well, then "...check the following: throttle operation and throttle grip free play.
intake air leak or engine top-end problem
IACV operation.
Take in if you think its wrong. Idle is set by the computer based on a number of sensor inputs, etc. VFRpaul can probably explain it in detail.
OH, 1.2 is within spec. 1100 +- 100 rpm when warm
Thanks Ferret.
Hey popgun have you got the owners manual or work shop manual?
Shop manual
Edit to add. This was discussed some time ago and one user found what he thought was an idle adjustment screw.
There isn't one and that was for something you DON'T want to mess up.
Booked in for first service and the mechanic agrees to 1.2, normal.
Popgun were did you get the workshop manual?
The Honda dealer. Or you can order direct from Helm. Its in the owners manual.
http://www.helminc.com/helm/homepage.asp?r=
Helm prints the manuals, even the one you get at the dealer. Cost is around $65 if I recall correctly.
Thanks, popgun.
  CB1100 Idle speed instability problem ericlo69_imp 1,434 119,632 07-26-2026, 01:51 AM
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 895 10-22-2025, 02:11 PM
  Install a 6-speed trans on a 2013? amacbeth_imp 37 3,307 02-21-2023, 12:22 PM
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,440 06-03-2022, 01:16 PM
  Speed bleeders Raceman_imp 21 1,599 12-14-2021, 04:30 AM
  speed sensor output Lord Popgun 16 1,144 10-09-2020, 09:20 AM
  5 Speed, extra tooth Rogerdj_imp 2 331 09-12-2020, 08:01 PM
  RE: CB1100 Idle speed instability problem Lambchops_imp 52 3,644 07-09-2020, 08:06 AM
Last Post: SportsterDoc
  Bike surging at speed dsan1964_imp 13 972 07-05-2020, 02:45 AM
