Bike surging at speed
Hello C Bers it been a while since I have posted. Been getting my rides in regularly. I have noticed now that on freeway 75 to 80. Holding steady. It has been stumbling , I wanted to think it was gusty winds. Any chance someone else has experienced the same. I have already been down with the idle problems it hasn’t happened in years now. My only cure has been ride it harder... lol. Thank you hope all are safe and well !!
So not an idle issue but surging at 75 to 80 miles an hour? Moderators may move this to a new thread..
How many miles on the clock?
Condition of spark plugs?
Condition of battery cables and ground.
Fuel recently purchased?
Confirm that it does not stumble hesitate or otherwise misbehave when the throttle is cranked open further?
21k. On miles
New fuel
Battery full charge good cables
Spark plugs original
No stumbling when accelerating
Only at constant speed and intermittent
Depending on the severity and how it manifests itself could be hesitating around 3000 rpm because of the oxigen sensor leaning out the mixture, ( on off on off etc. ) that would feel like a slight stumble with irregular timing as if you move the throttle.
Initially i did not notice it but over time it started to annoy me, gets more noticeable at lower gearing.
solution; oxigen sensor eliminator, i finally installed my 330 ohm resistor and it is smooth now
Possibly have a look if any codes have been set with the mil light.
Could get more complicated from there on.
I'd run a tank of Stabil through it
The service manual specifies changing the spark plugs every 8,000 miles. If your originals are still installed, they could be going bad.
I have a new set of plugs sitting on work bench... I will throw them in, tighten ground terminal, fuel treatment... and hope for the best. Thank you all
Let us know how it goes, dsan?
Hey I said Stabil above, but I meant Seafoam. Pour about 5 ounces of Seafoam into a fresh full tank of gas and run it through.
(06-26-2020, 09:38 PM)Cormanus_imp Wrote: Let us know how it goes, dsan?
Absolutely... thank you
(06-26-2020, 09:54 PM)The ferret_imp Wrote: Hey I said Stabil above, but I meant Seafoam. Pour about 5 ounces of Seafoam into a fresh full tank of gas and run it through.
Ok got it.... thank you
  CB1100 Idle speed instability problem ericlo69_imp 1,436 123,603 Yesterday, 12:54 PM
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 921 10-22-2025, 02:11 PM
  Install a 6-speed trans on a 2013? amacbeth_imp 37 3,541 02-21-2023, 12:22 PM
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,481 06-03-2022, 01:16 PM
  Speed bleeders Raceman_imp 21 1,691 12-14-2021, 04:30 AM
  speed sensor output Lord Popgun 16 1,195 10-09-2020, 09:20 AM
  5 Speed, extra tooth Rogerdj_imp 2 337 09-12-2020, 08:01 PM
  RE: CB1100 Idle speed instability problem Lambchops_imp 52 3,843 07-09-2020, 08:06 AM
Last Post: SportsterDoc
  Looking for a Speed bleeder P/N for Clutch Slave Cylinder venturer434_imp 6 956 10-14-2017, 09:01 PM
Last Post: venturer434_imp
