New speed meter replacement
Hi there.Just got my oem speed meeter replaced.Have engine pgm fault lights on.Got misfired on high revs as well.Should I bring it to honda garrage to call on new speed meeter?
If you've replaced the original meter assembly with a smaller aftermarket one, there may not be a good solution. Those universal "fit all bike" meters work best on simple singles and twins, primarily older ones.
Several others have done the same before with similar complaints, and we have been largely unable to provide much help, mostly because there is no comprehensive wiring diagram or instructions for them.
You can search our database for similar posts and they may help some. If you replaced with an oem meter assembly, let us know what year you have.
(01-31-2025, 09:25 PM)m in sc_imp Wrote: the ecm sends data back and forth thru the stock gauge cluster to a degree . It's looking for a return signal its no longer getting and faulting out. what did you replace it with?
Its same genuine honda part number.Should I call in new speed meeter ?I ve got engine fault .
Same OEM part—I would read out the fault code if I were you and then we can probably narrow the problem down.
Why was the original meter replaced?
  CB1100 Idle speed instability problem ericlo69_imp 1,434 117,147 07-26-2026, 01:51 AM
  CB1300 headlight bucket replacement spechg 5 359 03-16-2026, 10:12 AM
  HISS Key replacement UK Davidjill_imp 12 899 01-19-2026, 05:09 AM
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 843 10-22-2025, 02:11 PM
  Rear brake pad replacement LongRanger_imp 39 3,457 05-03-2025, 10:45 AM
Last Post: Delphisa
  Fork Pipe replacement suggestions danieljrmurray_imp 3 473 10-09-2023, 02:31 AM
Last Post: danieljrmurray_imp
  Install a 6-speed trans on a 2013? amacbeth_imp 37 3,126 02-21-2023, 12:22 PM
  Fuel filter replacement Mafd2_imp 36 2,818 02-11-2023, 01:54 AM
  Replacement Battery dave 54 3,799 02-04-2023, 12:41 PM
  2013 replacement wheel Randy B 8 762 11-13-2022, 10:32 AM
Last Post: Randy B
