Public Service Announcement - Speed Sensor Clip
Hi all,
I was giving my CB a wipe-down last night, and when I got to the swing arm area, I noticed that the small speed sensor wire was loose from the brake hose. Turns out that the little black clip that holds the wire and clamps it to the brake hose was loose. When I tried to reattach it to the brake hose, it broke into two pieces.
Not a huge deal, but I didn't want the wire to be loose. I zip-tied it to the brake hose and searched for the part number for the clip.
It's HONDA PIPE CLAMP 11152-KS4-003 (R2244)
Ordered two from Ebay to have a spare once I replace the broken one.
Check your speed sensor wire, folks!
(10-17-2025, 10:10 AM)Gone in 60 Wrote: Hi all,
Made me go out in the garage and check mine.  All good!
But, that looks like a thing to have a spare for.  Thanks for the heads up!
Holder of the CB1100forum Secret Decoder Ring
2012 ST1300
2013 CB1100
I find your lack of RLETs disturbing
(10-17-2025, 10:10 AM)Gone in 60 Wrote: Thanks for the tip, Gone in 60. Mine looks good. That's a pretty hefty metallic clip, do you know why yours broke? Was it rusted?
Dave, there is a plastic clip too closer to where the brake line connects to the caliper.
2012 ST1300
2013 CB1100
(10-19-2025, 06:03 AM)Lord Popgun Wrote: Dave, there is a plastic clip too closer to where the brake line connects to the caliper.
Thanks Lord, found it. My sensor wire was actually detached from this clip, and I reattached it! Clip looks good!
Got my replacement clips, reattached my speed sensor wire, stored the spare in my box labelled "Honda Parts" if ever needed. All is good, the balance has been restored.
Was the RLET imbalanced due to this clip? Smile
           "Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan®
            *Grand Chancellor*
(10-22-2025, 01:29 PM)peterbaron Wrote: Was the RLET imbalanced due to this clip? Smile
No, thankfully. I believe the RLET Balance actually held the clip together.
The clip was clearly weakened but was still holding together until I broke the clip while wiping down the swingarm in the area of the hoses.
Hoping to avoid possible disruption in The Force, while I did temporarily attach the speedo cable with a zip tie, I avoided riding the bike until the clip was received and replaced.
  CB1100 Idle speed instability problem ericlo69_imp 1,434 121,028 07-26-2026, 01:51 AM
  O2 sensor eliminator not working on CB1100rs 2017 tory_imp 33 2,976 03-06-2026, 04:31 AM
  Service manual Billie_imp 32 3,080 11-27-2025, 06:35 AM
Last Post: TheLegend
  Oxygen lambda o2 sensor eliminator kit Davidjill_imp 4 583 11-09-2025, 06:23 AM
Last Post: AndyBeeMD
  How to remove O2 sensor CB1100AZ_imp 10 948 12-13-2024, 09:57 AM
Last Post: inditx_imp
  How To do your own 600 mile service the Ferret 163 11,428 08-10-2023, 07:42 AM
  Bank angle sensor. Tezza_imp 8 801 08-06-2023, 05:57 PM
Last Post: Jurlie_imp
  2018 CB1100EX just collected from service Motorsport3_imp 5 562 05-10-2023, 11:25 PM
Last Post: Motorsport3_imp
  Preparing to do a fork service, any advice? skidmarkart_imp 12 1,272 04-23-2023, 01:35 AM
