HELP GAUGE REMOVAL /CUSTOM TACH
Thanks, popgun. All good this end. I'll report in due course.
Cormanus,
I made a mistake. That was for the 14 model. Our bikes only have 2 connectors. Misread the man. Glad I looked at the wiring diagram.
Its the same though, only just remove 1 and 2. We don’t have connector 3
I just shot you the right manual page.
Thanks popgun. Of course there are at least 3 x 6P connectors. I've emailed you.
OK. With heaps from help from the ever-generous popgun, I think I've isolated the instrument cluster by disconnecting it. There is no action on the instruments when I switch on the cluster, but the bike starts fine. I've not ridden it.
Just to be clear—because, as I say, there are 3x6P connectors in the headlight shell one of which has to be disconnected along with a 10P connector, and because I'm no expert at these things—I disconnected the 10P connector (easy; there's only one of it) and a white 6P connector on the basis of the fact that they appear to exit the headlight shell bundled in the same wrapping.
If there's something wrong with that logic, I will go and have another look.
(02-11-2018, 03:37 AM)911jimmy_imp Wrote: Sorry it's the 2014 ..
So theres absolutely no way ever to make it work ?
What would the Japanese do?
They would use the stock gages.
If you were to tear apart the gage housing, you would find computer circuitry needed to process the bike's data critical to operation.
If you were really clever you could remove only the circuit boards needed, put them into a small, separate housing, and locate that inconspicuously somewhere, like, under the seat. Run the CANBUS line to it and connect everything exactly the same as if it were the gage cluster.
The mechanical gages don't need to be connected, but, who knows how they've been integrated into the circuitry? The whole thing may be nearly impossible.
Just use the stock gages because a bike that don't run ain't much.Wink
Just so everyone knows, the wiring diagram and manual do not tell the connector color of the 6P. I did send him the wire colors...
2013 gages ain't gonna work with the 2014. No way.
No, he knows that. He said in an email to me that they considered using a ‘13 harness on a 14 bike if all would be good with the meters gone. It won’t all be good. Your suggestion above would be better. Much better.
This forum is amazing. Some cat pokes his head in here with a strange modification question (which, on this forum could be shunned) and Cormanus runs out to his garage to help the guy out. Not only does Cormanus not know exactly what he's doing but also has to get into his headlight bucket, never a fun place to be. I gotta say, that is a very generous act sir. Very, very well played. Simply awesome.
Thank you, Bheezy, but I could not have done it without popgun’s help. In my view, Jimmy should leave the gauges alone, but, hey, it’s his bike.
Agreed that popgun helped as well but he just pressed a few buttons. You sir went above and beyond and turned a wrench or two. I would rather go to the dentist then get in the headlight bucket. I've never been in the CB's but if it is like any other bike I've had (can't imagine it's not) it's no fun.
Don't down play it. A random clown joins the forum to ask a rather strange question and you drop everything and help him out. Thumbs Up
No offense to the "random clown". Big Grin
  Valve Adjustment and Camshaft Removal dave 5 624 03-21-2026, 04:49 PM
  Left side cover removal jeffmazz_imp 24 2,089 07-09-2025, 03:37 PM
Last Post: bflint
   Digital tach shorting out kentf1120_imp 1 249 03-16-2023, 09:33 AM
  Clock Speedo and Tach died while riding adogsnyder99_imp 2 353 06-15-2022, 01:00 AM
Last Post: 17-CB-002
  Easy bar end weight removal brian10x_imp 6 619 06-06-2022, 01:04 AM
Last Post: 1973cb750
  Fuel gauge flashing from center outward.... mattmcuomo@yahoo.com 29 2,313 06-02-2022, 03:13 AM
Last Post: thomas_imp
  Explanation of 2014 Fuel Gauge the Ferret 28 1,897 04-27-2022, 01:46 PM
Last Post: ChiefJP_imp
  CB 900C Custom Spark Issue goatman64_imp 3 369 11-27-2021, 07:11 AM
  CB900 Custom oil stopper on valve head AOrhun_imp 9 791 01-27-2021, 10:06 PM
  Air box removal ACE_IRA_imp 23 1,632 09-25-2020, 05:56 AM
Last Post: ACE_IRA_imp
