low oil pressure light kaput
(03-27-2023, 10:53 PM)1973cb750_imp Wrote:
(03-27-2023, 01:09 PM)max_imp Wrote: One more thing; what is the volt meter reading between the DISCONNECTED oil pressure switch wire and ground with the ignition switch in run?
i've always checked those with continuity cb doesn't use a ground interrupted switch for the dummy light ?
Absolutely right 73, that's what we normally do, check continuity with an appropriate load like a 12v light.
Just this time i thought as a second test it may be an idea to disconnect the oil pressure switch terminal and see what is happening at the led's supply side, if it was open or if some supply is still present, just an idea.
^^Thumbs Up^^
  low oil pressure light Garuda78_imp 16 1,099 02-29-2024, 04:09 PM
Last Post: Garuda78_imp
  CB1100ex Tires pressure, when changed tube to tubeless tory_imp 10 905 10-09-2023, 07:51 AM
  Interesting article on tire pressure the Ferret 9 828 11-28-2021, 04:23 AM
Last Post: j3gq_imp
  Cold Weather & Tire Pressure 2017EX_imp 22 1,365 11-28-2019, 08:53 PM
Last Post: Cqrlm911_imp
  Catalytic converter back pressure? ChipBeck_imp 13 950 05-26-2019, 01:42 AM
Last Post: HondaJon_imp
  running light and brake light Ennsync_imp 3 432 01-02-2019, 11:24 PM
  Rear Brake Intermittent Loss of Pressure beardyweirdy@me.com_imp 9 651 11-04-2017, 12:26 AM
Last Post: Dengie Boy_imp
  Tire pressure Sonnyboy_imp 4 433 10-23-2017, 04:51 AM
Last Post: kennyw
  Tire pressure glynb_imp 12 883 09-29-2017, 03:00 AM
  Oil filter failure.... Complete loss of oil pressure x(why)z_imp 49 2,924 09-14-2017, 10:12 PM
Last Post: paulw_imp
