Tire pressure
What tire pressure do you all prefer? I have a 2014 standard and I weigh about 220lbs.
I just stick with the Honda recommended 36 in front, 42 for the rear.
I agree, stick with the recommended pressures and you should be fine.
(10-20-2017, 10:59 PM)DocRid_imp Wrote: I just stick with the Honda recommended 36 in front, 42 for the rear.
Thanks for your input!
Thanks, guys.
I run 40 psi to prevent cupping on the front tire and the standard 42 on the rear. I have had less issues with cupping after upping the pressure on the front.
  low oil pressure light Garuda78_imp 16 1,072 02-29-2024, 04:09 PM
Last Post: Garuda78_imp
  CB1100ex Tires pressure, when changed tube to tubeless tory_imp 10 846 10-09-2023, 07:51 AM
  low oil pressure light kaput norton1974_imp 11 975 03-28-2023, 08:58 AM
  Interesting article on tire pressure the Ferret 9 794 11-28-2021, 04:23 AM
Last Post: j3gq_imp
  Cold Weather & Tire Pressure 2017EX_imp 22 1,257 11-28-2019, 08:53 PM
Last Post: Cqrlm911_imp
  Catalytic converter back pressure? ChipBeck_imp 13 883 05-26-2019, 01:42 AM
Last Post: HondaJon_imp
  Tire replacement - Not a "Tire Thread" SportsterDoc 12 940 07-18-2018, 06:50 AM
Last Post: SportsterDoc
  Rear Brake Intermittent Loss of Pressure beardyweirdy@me.com_imp 9 629 11-04-2017, 12:26 AM
Last Post: Dengie Boy_imp
  Tire pressure glynb_imp 12 807 09-29-2017, 03:00 AM
  Oil filter failure.... Complete loss of oil pressure x(why)z_imp 49 2,856 09-14-2017, 10:12 PM
Last Post: paulw_imp
