Tire pressure
Hey guys,
Long term owner and forum member here. I just had my front Bridgestone Battleax tire replaced today at only 4000 miles. The rear tire is in great shape. I'm concerned because the tire lasted so few miles. The wear pattern was even across the tire with no cupping.
Which leads me to tire pressure. I usually run 36 psi front and 42 psi rear. I was advised of the pressure from the dealer.
I know this is a dumb question but is that the right psi for the front tire? I know the max is 42 psi with a maximum load, but what psi do you guys run for a non loaded bike?
well is there no adhesive image on the rear swing...or info in the driver's handbook
i meant , normal are 3.9bar or 56psi in rear by that bike weight
I'm running 36/42 like you and get similar mileage from my front BT54's.
(09-27-2017, 04:35 AM)alprider_imp Wrote: well is there no adhesive image on the rear swing...or info in the driver's handbook
56 is far too high , I run 42 for 220 lbs rider plus all the gear.
The owner's manual for my '14 calls for 36 front and 42 rear so I don't argue with that.
As a matter of fact, my '02 CB900F (919) also calls for the same pressures.
in principle is still the bikeweight decisive..how much ....and ev. some supplment with passenger
Besides the owner’s manual, there is a sticker on the frame neck that has the tire pressure settings. 36/42
The front bs wears out early because it only has 4/32 tread to begin with according to Bridgestone. If you replace when recommended at 2/32 that means you only get 2/32 of tread to use. THe rear bs has 9/32 tread.
Look up thread "Front tire replacement" by Longranger for particulars.
Hey Guys,
Thanks for all of the replies. I'm glad I was right with the tire pressure, and thanks for the info about the tread depth on the front tire.
38 in front. 40 in rear.
  low oil pressure light Garuda78_imp 16 1,092 02-29-2024, 04:09 PM
Last Post: Garuda78_imp
  CB1100ex Tires pressure, when changed tube to tubeless tory_imp 10 899 10-09-2023, 07:51 AM
  low oil pressure light kaput norton1974_imp 11 1,034 03-28-2023, 08:58 AM
  Interesting article on tire pressure the Ferret 9 821 11-28-2021, 04:23 AM
Last Post: j3gq_imp
  Cold Weather & Tire Pressure 2017EX_imp 22 1,343 11-28-2019, 08:53 PM
Last Post: Cqrlm911_imp
  Catalytic converter back pressure? ChipBeck_imp 13 939 05-26-2019, 01:42 AM
Last Post: HondaJon_imp
  Tire replacement - Not a "Tire Thread" SportsterDoc 12 965 07-18-2018, 06:50 AM
Last Post: SportsterDoc
  Rear Brake Intermittent Loss of Pressure beardyweirdy@me.com_imp 9 647 11-04-2017, 12:26 AM
Last Post: Dengie Boy_imp
  Tire pressure Sonnyboy_imp 4 430 10-23-2017, 04:51 AM
Last Post: kennyw
  Oil filter failure.... Complete loss of oil pressure x(why)z_imp 49 2,903 09-14-2017, 10:12 PM
Last Post: paulw_imp
