Headlight shell
(10-04-2025, 08:44 AM)Lord Popgun Wrote: Yesterday the turn signal switch started sticking some so today I’ll address that.
Let me know what you discover. Mine would stick in colder weather, but in warm weather it worked fine. I think Honda used an incorrect grease that thickens up too much when the temperature drops.
Didn't really see much. The grease was mostly OK and clean. Small amount of dirt but not like I thought it would be. As the bike is a '13 I thought the grease would have been caked, but it was not.
I just sprayed it out with CRC QD Electronic Cleaner then greased it with some I had in the garage. It looked the same as the factory Grease. Had to use a tooth pick to get it on all the surfaces. Anyway it is all good now. Easy job, and I covered the tank with some plastic. Just in case...
Holder of the CB1100forum Secret Decoder Ring
2012 ST1300
2013 CB1100
I find your lack of RLETs disturbing
  2017 MY CB headlight upgrade. 17-CB-002 16 2,340 09-06-2025, 05:00 PM
  auxiliary 12v in headlight shell Maturecheese_imp 6 669 03-25-2023, 07:14 AM
  Delay when using headlight switch? Jgarciajr40_imp 15 1,166 12-05-2022, 07:11 AM
Last Post: max
  Headlight shell acc connector HBFL_imp 2 351 08-28-2022, 08:18 PM
Last Post: HBFL_imp
  headlight adapter j3gq_imp 15 1,224 07-18-2022, 04:12 AM
Last Post: max
  Melted headlight Lord Popgun 6 600 05-23-2021, 03:59 PM
Last Post: LikeAfox_imp
  Headlight bulbs Randy B 80 6,230 05-17-2021, 01:42 AM
Last Post: Zee9_imp
  Headlight malfunctioning Ernie_imp 11 936 12-31-2020, 04:50 AM
Last Post: max
  headlight not compatible? GroovyBunny86_imp 11 928 12-06-2020, 10:49 PM
  Headlight is absolute junk! FLYTYM_imp 23 1,612 06-24-2019, 06:07 PM
Last Post: FLYTYM_imp
