Headlight malfunctioning
Hi All
My light and low beam are not working, however the overtaking high beam flasher works and the low beam flickers on during engine starter engaged during starting. Anybody here experienced anything similar before I start quessing.
Thanks DT
Check the fuse first and try a new bulb.
Clean out the ignition switch. A dirty terminal can cause low beam not to work. It’s something to do with the part of the switch that turns the light off as you crank the bike.
What Cormanus said. Then we can go from there.
We aren’t good at guessing here. Logical troubleshooting will lead to problems getting fixed without throwing parts at it or just guessing. We can help with that.
Does the headlight circuit disable when the starter is asserted?
If so, could it be a flakey relay?
(12-28-2020, 08:19 PM)Ernie_imp Wrote: Hi All
Thanks DT
This is a good clue. There is a switch that is supposed to cut out the headlight when the engine cranks. It's purpose is to reduce the load on the battery when starting. The fact that your low beam is flickering with the starter engaged would suggest that the switch or its connections are going bad.
I've never had a problem with this, but I know that the cutoff switch is located in the housing with the starter button.
Edit : It seems that this is a common Honda issue. Google "honda headlight cut off switch" and you'll see a lot of similar problems.
Thanks DT
Thanks all.
I will clean up contacts in the engine start and cutoff switch housing on the weekend and report back. I suspect this component is faulty as the engine cutoff switch did have an intermittent fault some years ago but it self repaired.
I have looked at the fuses and tried a new bulb...... no joy.
Thanks for the tips
Ernie
Ernie Flynnrider is on the ball, the headlight uses the normally closed contacts of the engine start switch ( the black one that starts the engine ).
It normally conducts the headlamp supply unless the switch is pushed to start the engine, it then brakes the circuit ( to save energy and re-connects the headlight to low or high beam.
This switch is independent of the high beam signal switch on the left hand handle bar.
which explains why this switch is functioning as intended.
The previous issue with the red engine stop switch suggests some moisture has worked itself into the handle bar switches.
Here is a simplified diagram if that helps;
Could be some contact spray and some motivation of the switch may solve the issue for you or simply bypass that switch and connect the wires of the normally closed contacts together so the headlights are just on all the time, cheers.
Max, thanks for that. I was going to have to delve in to the diagram and now I don’t!!
NZ to the rescue again! Big Grin
(12-29-2020, 04:58 PM)max_imp Wrote: Ernie Flynnrider is on the ball, the headlight uses the normally closed contacts of the engine start switch ( the black one that starts the engine ).
Thanks Max
A quick tap of the starter switch bought the headlight back on, so that is my problem. A cleanup and away again.
I have been using my CB to commute to work for the last month now and I notice that it runs very smoothly with the constant use.
Ernie
  Headlight shell Lord Popgun 11 1,575 10-08-2025, 01:17 PM
  2017 MY CB headlight upgrade. 17-CB-002 16 2,326 09-06-2025, 05:00 PM
  auxiliary 12v in headlight shell Maturecheese_imp 6 659 03-25-2023, 07:14 AM
  Delay when using headlight switch? Jgarciajr40_imp 15 1,163 12-05-2022, 07:11 AM
Last Post: max
  Headlight shell acc connector HBFL_imp 2 347 08-28-2022, 08:18 PM
Last Post: HBFL_imp
  headlight adapter j3gq_imp 15 1,204 07-18-2022, 04:12 AM
Last Post: max
  Melted headlight Lord Popgun 6 600 05-23-2021, 03:59 PM
Last Post: LikeAfox_imp
  Headlight bulbs Randy B 80 6,145 05-17-2021, 01:42 AM
Last Post: Zee9_imp
  headlight not compatible? GroovyBunny86_imp 11 922 12-06-2020, 10:49 PM
  Headlight is absolute junk! FLYTYM_imp 23 1,595 06-24-2019, 06:07 PM
Last Post: FLYTYM_imp
