Replacement turn signals
Mikestib1_imp Offline
Threads: 19
Had a crash and the front turn signal broke. The body is about as thick as a Xmas tree ornament and $65. Anyone find a better quality reasonably priced ones? No Rizoma thank you, just a functional replacement. Plan to replace both fronts that have dual element bulbs and wiring. I guess Honda was trying to save weight on a 540 pound bike by a few ounces. Emgo maybe? Thanks. Need to spend my money on the right crankcase cover, brake pedal. And a muffler. Will go with a Yoshi slip on to save over the stock one
11-19-2016, 04:51 AM
Rocky_imp Offline
Threads: 26
RE: Replacement turn signals
No info for you, but I'm sorry to hear about the "incident."
11-19-2016, 05:24 AM
Threads: 19
(11-19-2016, 05:24 AM)Rocky_imp Wrote: No info for you, but I'm sorry to hear about the "incident."
Luckily it was only cracked and broken but all in one piece. Used a tooth pick to apply glue then used tape to hold it until the glue cured. Removed the tape and so far so good
11-19-2016, 08:23 AM
Randy B Offline
Palm Bay, Florida USA
Threads: 85
Likes Given: 133
Why is the right front $30 more than all of the others?
11-19-2016, 09:01 AM
MikeD_imp Offline
Threads: 15
Dime City has a lot of options. These are $30 for the pair.
http://www.dimecitycycles.com/vintage-ca...320cm.html
11-19-2016, 09:42 AM
flynrider Offline
Phoenix, AZ
Threads: 28
Likes Received: 6 in 2 posts
(11-19-2016, 04:51 AM)Mikestib1_imp Wrote: Had a crash and the front turn signal broke. The body is about as thick as a Xmas tree ornament and $65. Anyone find a better quality reasonably priced ones? No Rizoma thank you, just a functional replacement. Plan to replace both fronts that have dual element bulbs and wiring. I guess Honda was trying to save weight on a 540 pound bike by a few ounces. Emgo maybe? Thanks. Need to spend my money on the right crankcase cover, brake pedal. And a muffler. Will go with a Yoshi slip on to save over the stock one
Muffler you say? Roger the Shrubber just posted a stock one for sale.
http://cb1100forum.com/forum/showthread.php?tid=9833
11-19-2016, 10:48 AM
  LED Headlamp Replacement Davidjill_imp 14 1,449 12-31-2024, 02:21 AM
  Yoshimura RS3 replacement for an '13 Jurlie_imp 7 676 07-28-2024, 01:47 PM
Last Post: Glockrocks83_imp
  LED Turn Signals deuce17EX 23 2,377 03-12-2024, 10:58 AM
  Hepco Becker Replacement Key tomcat_imp 5 600 08-10-2023, 03:20 AM
  LED turn signals Elipten_imp 32 2,436 01-05-2023, 05:15 PM
Last Post: CptMoustache_imp
  Any aftermarket Turn signals plug and play? gretle_2.0 5 674 05-30-2022, 07:05 AM
Last Post: bioman_imp
  Turn signals option USA in EU Łukasz_imp 7 675 02-08-2022, 12:18 AM
  Identify these? Turn signals RandyBMC_imp 3 374 11-11-2021, 09:23 PM
  Wrecked my CB, need OEM or Aftermarket replacement suggestions danieljrmurray_imp 12 904 09-15-2021, 05:51 AM
Last Post: teamvisegrip_imp
  valve stem replacement without removing tyre max 5 546 01-08-2021, 10:46 AM
