LED turn signals
Elipten_imp Offline
Threads: 13
LED turn signals
For those that want to install LED turn signal bulbs in the stock turn signals or replace the turn signals with LED units, here is what is required.
The stock Honda flasher unit will hyperflash if LED replacement lights are installed.
One can purchase a digital flasher made by Posh for the CB1100. Very easy install, no modification to the wiring harness. I bought the unit from Samurider, just under $100.
The replacement is slightly longer than the stock unit. No fear
Lift gas tank, locate original flasher on left front area under the tank. Disconnect the two electrical connections.
Remove unit, remove the rubber band that holds it in place. Install the rubber band on new flasher unit. Even though the new unit is longer it will fit, just make sure the wire running to the left and around is not trapped under the flasher. Reinstall the tank and you are done. No more hyperflash.
Enjoy!
04-07-2015, 11:34 AM
zachamo_imp Offline
Threads: 1
RE: LED turn signals
Without any experience for reference, this seems expensive for the seemingly simple task it performs, but without the actual expertise myself and given this is exactly what I want I am tempted. Thanks for the idea and how-to.
04-07-2015, 11:58 AM
Elipten_imp Offline
Threads: 13
LED turn signals
Yes I agree, but sadly it does not take or use cheap digital flasher unit that most bikes can use. I looked for months but finally gave up as my time is worth something. At least no cutting or modification of the wiring harness.
If someone finds a cheaper alternative I am all ears, as I still have my 2013 CB I would like to modify, but I drew a line at one.
04-07-2015, 12:04 PM
Hedge_imp Offline
Threads: 10
(04-07-2015, 11:34 AM)Elipten_imp Wrote: For those that want to install LED turn signal bulbs in the stock turn signals or replace the turn signals with LED units, here is what is required.
Enjoy!
Very nice and simple directions. Thanks for dropping that knowledge on us! Thumbs Up
04-08-2015, 04:49 AM
KennyB_imp Offline
Threads: 2
Having installed more LED turn signals on bikes over the years than I can count, the simple, quick and inexpensive solution for slowing down the flash rate is to wire a resistor in line. They can be purchased ready to install from several parts distributors that your local dealer probably has the catalogs for. The CB1100 wiring is so easily accessible a first time DIYer should have no trouble. Just do it!
04-08-2015, 09:19 AM
Elipten_imp Offline
Threads: 13
LED turn signals
Yes I thought about the resistor option, but need to install and previous experience those resistors get hot. This way I reduce the electrical current use and make it available for other accessories.
04-08-2015, 09:22 AM
CSODenmark_imp Offline
Threads: 2
Unfortunately, the POSH part are not in stock at Samurider or japan.webike. I have ordered one from Samurider, but I don’t know if the relay ever coming on stock again.
I have just fallen I love with LED Turn signals from http://motogadget.com/en/turn-signal-lights.html for my new caferacer.
Just want to do it the correct way instead of resistors.
07-30-2016, 02:32 AM
kmoney_imp Offline
Threads: 29
The resistor idea sucks for these bikes though. Firstly, there isn't that much room in the headlight bucket. Also, since our front signal lights are also run lights, the resistors are always 'working' and get hotter than they would in signals that are signal only. I had mine set up this way, debated trying to wire in a universal solution, then gave up and bought this POSH unit -- totally worth it...
07-30-2016, 11:45 AM
jamestkirk_imp Offline
Threads: 3
Resurrecting an old thread.....
I like the LED's not just for their longevity but for their brightness as well.
My bike is hyperflashing now, anybody find a more affordable solution besides soldering resistors?
Not sure if the hyperflashing really bothers me though. It sort-of brings attention to me when signalling. Kind-of like the modulating headlight...
Kirk Out
09-01-2018, 03:45 AM
Threads: 3
Here's the flasher unit on webike:
https://japan.webike.net/products/21124583.html
09-01-2018, 06:19 AM
  LED Turn Signals deuce17EX 23 2,377 03-12-2024, 10:58 AM
  Any aftermarket Turn signals plug and play? gretle_2.0 5 676 05-30-2022, 07:05 AM
Last Post: bioman_imp
  Turn signals option USA in EU Łukasz_imp 7 675 02-08-2022, 12:18 AM
  Identify these? Turn signals RandyBMC_imp 3 376 11-11-2021, 09:23 PM
  Anyone fitted Rizoma iRide turn signals to CB1100EX? Richard_imp 8 818 05-20-2020, 09:58 PM
Last Post: Richard_imp
  Lockhart Phillips Turn Signals-Lucas Tail Light ChipBeck_imp 43 3,179 04-17-2020, 07:25 AM
Last Post: gman_imp
  RELOCATION OF REAR TURN SIGNALS ART_imp 28 2,021 02-08-2019, 01:50 PM
  Self canceling turn signals Obleo 19 1,114 04-24-2017, 08:10 PM
Last Post: Tezza_imp
  Replacement turn signals Mikestib1_imp 5 575 11-19-2016, 10:48 AM
Last Post: flynrider
  Hard bags without moving the turn signals glynb_imp 3 318 07-29-2016, 09:52 PM
