Wrecked my CB, need OEM or Aftermarket replacement suggestions
danieljrmurray_imp Offline
Threads: 5
Hey y'all, new to the CB life. Threw down nearly 2400 miles I'm 2 months on the sweet 2013 I snagged from an old retired fella for $3800 (WHAT A STEAL, and it's ABS). I was riding on an unfamiliar road in the dark when it was super smokey here in Oregon and did a big doozy and wrecked the bike. It's luckily cosmetic damage. I need suggestions for a new instrument cluster, I do find the OEM one bulky and I'm sure it's expensive. Any quality after market suggestions? I will also need a new exhaust tip, I was thinking of the Arrow slip on as it looks OEM but is slimmer. I also like the bike quiet for my 5am commutes. It needs new side covers and a new right side peg and brake lever. The headlight housing and trim ring also took some damage. The bars got bent and so did the center stand. Any and all suggestions are welcome. I thank my lucky stars my tank only got the tiniest clear coat knick considering the bike slammed me to the ground at 30+mph and slid 30ft or so. All in all, I walked away with a minor concussion and some bruises, mostly to my ego. I'm still waiting to hear back from insurance about whether or not they are going to total it but I'm anticipating the worst case scenario. But you best believe this is the most brilliant bike I've ridden and I'll for sure be fixing it up even if they total it because there's no way I'm finding one for that price again.
09-13-2021, 06:49 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
RE: Wrecked my CB, need OEM or Aftermarket replacement suggestions
Due to the way information travels between the meters and the ECU (especially with ABS) OEM meter replacement is the only viable option. YMMV but others have had a nightmares getting other meters to work and then don't them to work correctly.
09-13-2021, 09:42 PM
Randy B Offline
Palm Bay, Florida USA
Threads: 85
Likes Given: 133
Front brake handle
https://www.hondapartshouse.com/oemparts...cylinder-2
Handlebar
https://www.hondapartshouse.com/oemparts...top-bridge
Headlight
https://www.hondapartshouse.com/oemparts.../headlight
Gauges (hold on to your shorts)
https://www.hondapartshouse.com/oemparts...3280/meter
Rear brake pedal
https://www.hondapartshouse.com/oemparts...3296/pedal
Right crankcase covers
https://www.hondapartshouse.com/oemparts...case-cover
Center stand
https://www.hondapartshouse.com/oemparts...3298/stand
Muffler (ooof....get either a used one or an aftermarket)
https://www.hondapartshouse.com/oemparts...st-muffler
09-13-2021, 10:08 PM
Houtman_imp Offline
Threads: 115
I have a set of silver side covers and a header and exhaust pipe available.
09-14-2021, 12:05 AM
Threads: 5
Thanks for all the responses so far. Also, that's about what I expected for that OEM guage cluster. Jesus cuss. Maybe I'll get lucky and find one on fleabay.
Does anyone know if a later model gauge cluster will work? I know that's probably a no since they changed the fuel gauge and added a 6th gear on the 2014+.
09-14-2021, 01:10 AM
Lord Popgun Offline
Virginia
Likes Given: 142
After 2014 meters will not work on the 2013. For 2014 and up there is a bi-directional serial data buss for Meter/ECU communication. The 2013 does not have that.
Plus what you said about the gear readout etc.
09-14-2021, 02:03 AM
teamvisegrip_imp Offline
Threads: 4
I have a complete 2014 exhaust system for sale $600 plus shipping. The system has just 2 miles on it so it is basically new. PM me if interested. Could be a cheap way to go. It will make it look stock too.
09-14-2021, 07:57 AM
Whoops Offline
Utah, USA
Threads: 31
Likes Received: 117 in 50 posts
Likes Given: 64
You have had that on eBay for a while now and I have had my finger come so close to hitting the buy button so many times now. Big Grin
All I needed was the exhaust pipe though which was what kept me from buying the whole assembly. Every time I tried to snag just the exhaust here on the forum the seller vanished. But yes, that is a super clean exhaust and looks brand spankin' new. Would be an incredibly inexpensive way to go rather than the dealer!
09-14-2021, 07:42 PM
Threads: 4
If we do it outside of eBay $500 and shipping and it is yours?
09-14-2021, 09:57 PM
Blockhead_imp Offline
Threads: 7
(09-13-2021, 06:49 PM)danieljrmurray_imp Wrote: Hey y'all, new to the CB life. Threw down nearly 2400 miles I'm 2 months on the sweet 2013 I snagged from an old retired fella for $3800 (WHAT A STEAL, and it's ABS). I was riding on an unfamiliar road in the dark when it was super smokey here in Oregon and did a big doozy and wrecked the bike. It's luckily cosmetic damage. I need suggestions for a new instrument cluster, I do find the OEM one bulky and I'm sure it's expensive. Any quality after market suggestions? I will also need a new exhaust tip, I was thinking of the Arrow slip on as it looks OEM but is slimmer. I also like the bike quiet for my 5am commutes. It needs new side covers and a new right side peg and brake lever. The headlight housing and trim ring also took some damage. The bars got bent and so did the center stand. Any and all suggestions are welcome. I thank my lucky stars my tank only got the tiniest clear coat knick considering the bike slammed me to the ground at 30+mph and slid 30ft or so. All in all, I walked away with a minor concussion and some bruises, mostly to my ego. I'm still waiting to hear back from insurance about whether or not they are going to total it but I'm anticipating the worst case scenario. But you best believe this is the most brilliant bike I've ridden and I'll for sure be fixing it up even if they total it because there's no way I'm finding one for that price again.
Welcome to the forum! Hello
09-15-2021, 12:42 AM
  LED Headlamp Replacement Davidjill_imp 14 1,485 12-31-2024, 02:21 AM
  Any suggestions for front and rear cameras? Davidjill_imp 2 362 10-14-2024, 11:19 AM
  Yoshimura RS3 replacement for an '13 Jurlie_imp 7 688 07-28-2024, 01:47 PM
Last Post: Glockrocks83_imp
  Hepco Becker Replacement Key tomcat_imp 5 608 08-10-2023, 03:20 AM
  Stock exhaust or aftermarket header? milkmaster_imp 17 1,414 07-20-2023, 04:11 AM
  Any aftermarket Turn signals plug and play? gretle_2.0 5 689 05-30-2022, 07:05 AM
Last Post: bioman_imp
  Hard luggage suggestions? run-tmc_imp 35 2,288 03-28-2022, 09:55 AM
  valve stem replacement without removing tyre max 5 569 01-08-2021, 10:46 AM
  Aftermarket Brake and Clutch Reservoir Covers michael1954 11 957 06-17-2020, 08:42 AM
Last Post: Mtneers
  Stock vs. aftermarket exhaust LongRanger_imp 15 1,098 11-30-2019, 06:30 AM
