Hepco Becker Replacement Key
tomcat_imp Offline
Threads: 6
Recently bought two used HB top cases. Not a fan of the plastic headed keys that HB has and would like to replace them. Looked at several Ilco keys, none of which is a replacement. Moto Machines has HB keys but 1 key is ~ $25 shipped and is the large plastic head key. Anyone know of key blanks or a source for replacement keys?
07-23-2023, 09:00 AM
RE: Hepco Becker Replacement Key
Agreed.
Can you smash up the red plastic shroud and drill a nice hole into the key? Or is the "Hepco & Becker" logo portion of the key independent of the key blade?
I am wondering if the extra plastic shroud provides leverage on those tough days when the tumblers are feelin' extra resistive?
07-23-2023, 09:43 AM
tomcat_imp Offline
Threads: 6
(07-23-2023, 09:43 AM)GoldOxide_imp Wrote: Agreed.
Thought about trying to grind, cut, or burn off the red plastic and drill a hole in the metal head. Searched to no avail for a key blank. Pain putting these types of keys on a key ring. Fortunately blanks are available for the big head CB1100 keys.
07-23-2023, 10:00 AM
Nachodaddy Offline
Litchfield Park, Arizona, USA
Threads: 10
Likes Received: 196 in 112 posts
Likes Given: 502
Thought about trying to grind, cut, or burn off the red plastic and drill a hole in the metal head. Searched to no avail for a key blank. Pain putting these types of keys on a key ring. Fortunately blanks are available for the big head CB1100 keys. tomcat, first you might check with a local locksmith. Sometimes they are your best resource. If they don't have it, then you might have to get creative. Good luck
07-23-2023, 10:39 AM
tomcat_imp Offline
Threads: 6
Used a Dremel to remove plastic shroud. Drilled a hole which also removed the HB logo. Not pretty but it's better.
08-10-2023, 01:20 AM
... I see. The point of the plastic shroud is to save money on metal?
08-10-2023, 03:20 AM
  [SOLVED] Are Hepco & Becker C Bow mounts compatible with the OEM Rear Rack? JRD 14 1,007 07-09-2026, 07:38 PM
Last Post: JRD
  LED Headlamp Replacement Davidjill_imp 14 1,563 12-31-2024, 02:21 AM
  Yoshimura RS3 replacement for an '13 Jurlie_imp 7 765 07-28-2024, 01:47 PM
Last Post: Glockrocks83_imp
  Hepco & Becker luggage Nitro_imp 12 1,147 03-20-2024, 03:37 AM
Last Post: Mitch_imp
  Wrecked my CB, need OEM or Aftermarket replacement suggestions danieljrmurray_imp 12 1,045 09-15-2021, 05:51 AM
Last Post: teamvisegrip_imp
  hepco becker side back C system alexzanutto_imp 16 1,727 07-31-2021, 07:34 AM
  valve stem replacement without removing tyre max 5 600 01-08-2021, 10:46 AM
  Hepco & Becker Luggage Installed CaptainChris_imp 61 4,742 12-12-2020, 11:51 PM
  Hepco Becker plus Honda OEM racks Mitch_imp 6 889 06-28-2020, 01:50 AM
Last Post: andyoz_imp
  Corbin seat with Hepco & Becker luggage Marcus_imp 10 953 10-25-2019, 11:48 PM
Last Post: mdharne_imp
