LED Headlamp Replacement
Davidjill_imp Offline
Threads: 23
Good morning
Does anyone have any experience of the following alternatives to the lack lustre 55W Halogen H4? I Have uprated to Nightbreaker but they don't last 5 minutes !
https://www.ledperf.eu/led-headlight-for...32997.html
Plus
https://www.ledperf.eu/round-and-chrome-...35510.html
or
https://www.ledperf.eu/nano-technology-l...43291.html
12-23-2024, 08:04 PM
The Gecko_imp Offline
Threads: 43
RE: LED Headlamp Replacement
I have seen a few guys going from LED back to H4 classic, for a much better light at night. One of them a near and dear friend, who showed me the difference in real.
Are you really trying to go the opposite way ?
One other aspect, make sure you find a matching connector for inside the headlight. There ain't much space and cutting wires before you know ... Ledperf does not seem to provide one.
12-23-2024, 11:07 PM
Frulk_imp Offline
Threads: 108
I replaced the stock bulb which burned out on a 2013 with a bulb recommended by another rider on this site. Called the FighterER H4 High/Low Beam LED.
Surface of the sun bright. Came with 2 in the box. Easy enough install. No wire cutting/splicing. Plug and play. Fairly inexpensive. Very happy with it so far.
Interestingly the bulb has a fan built into it for cooling and a decent sized heat sink to dissipate heat produced.
Box says it’s 2.5 times brighter than halogen bulbs. I believe it.
12-24-2024, 01:14 AM
Gone in 60 Offline
Blood Biker of the Apocalypse
Orange County, CA
Threads: 245
Likes Received: 1,196 in 513 posts
Likes Given: 968
I use LEDs in all of my bikes, very similar to what m in sc listed. Good light at night and great visibility.
A simple and cheap upgrade.
12-24-2024, 01:32 AM
Whoops Offline
Utah, USA
Threads: 31
Likes Received: 117 in 50 posts
Likes Given: 64
It’s kind of funny that you are all looking for LED options, meanwhile I wish there was an easy way to replace the stock LED with an incandescent on my EX.
12-24-2024, 01:50 AM
mvk24_imp Offline
Threads: 18
Likes Received: 2 in 1 posts
+1 for auxito. A bunch of us have been using them also
12-24-2024, 02:15 AM
Jurlie_imp Offline
Threads: 5
A question for guys that use LED H4 bulb replacement: do they blind the oncoming traffic? Did you try to have someone ride your bike towards you on low beam so you could check how bright is that for your own eyes?
12-28-2024, 11:44 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
Thats just mean. Or brilliant!! Smile
Pun intended…
12-28-2024, 12:57 PM
Gone in 60 Offline
Orange County, CA
Threads: 245
Likes Given: 968
When I mess with my headlight, I’ll park in a very dark place, get off the bike and walk way out in front of it and look at it and think, if I were in an oncoming car, would this blind me? I’ll adjust it so I’ve got a good beam on the road without being obnoxious to other drivers.
I had the forks serviced on my Triumph a few years back. Apparently the shop was careless in putting my headlight back on. A few days later, in daylight on my street, an oncoming driver flagged me down to stop.
He had a thick Scottish accent and yelled “Dammit lad, are you trying to blind everyone with your bloody bright lights?”
I looked and the headlight was aimed up a bit. I apologized and adjusted it.
12-28-2024, 03:23 PM
Jurlie_imp Offline
Threads: 5
(12-28-2024, 03:23 PM)Gone in 60_imp Wrote: When I mess with my headlight, I’ll park in a very dark place, get off the bike and walk way out in front of it and look at it and think, if I were in an oncoming car, would this blind me? I’ll adjust it so I’ve got a good beam on the road without being obnoxious to other drivers.
Thanks man, this is exactly what I wanted to know. Gonna order that LED myself.
Just to make sure: do these bulbs https://www.ebay.com/itm/375309758244?mk...media=COPY that m in sc suggested require any modifications?
12-29-2024, 03:23 PM
  Yoshimura RS3 replacement for an '13 Jurlie_imp 7 664 07-28-2024, 01:47 PM
Last Post: Glockrocks83_imp
  Hepco Becker Replacement Key tomcat_imp 5 594 08-10-2023, 03:20 AM
  Wrecked my CB, need OEM or Aftermarket replacement suggestions danieljrmurray_imp 12 898 09-15-2021, 05:51 AM
Last Post: teamvisegrip_imp
  valve stem replacement without removing tyre max 5 539 01-08-2021, 10:46 AM
  Bar end weight replacement Gone in 60 12 1,078 04-12-2019, 11:42 AM
  Vario Footpeg replacement mounting bolts Ojiisan_imp 2 348 04-19-2018, 03:07 AM
Last Post: Ojiisan_imp
  Replacement Passenger Footpegs hb9400_imp 3 358 10-05-2017, 10:16 PM
Last Post: hb9400_imp
  Beautiful replacement tank for the 2014 STD CB4ME_imp 23 2,739 01-11-2017, 03:30 AM
Last Post: Nortoon_imp
  Replacement turn signals Mikestib1_imp 5 573 11-19-2016, 10:48 AM
Last Post: flynrider
  Headlight bulb replacement zippooriginal_imp 3 414 09-19-2016, 04:21 PM
Last Post: kevbroce_imp
