LED Turn Signals
deuce17EX Offline
Threads: 3
LED Turn Signals
Ok, I hate to beat a dead horse, but I'm new to the CB1100 and want to upgrade the turn signals. From all of my researching on the web and this forum, it seems I can conclude the following:
1. The Posh Relay is unobtainable now, and is the only thing that truly fixes the hyperflashing.
2. Simple flasher relays from everywhere else are insufficient or don't hold up.
3. In-line resistors are also a no-go.
I have a 2017 EX and I just tried putting an LED bulb in and it hyperflashes. I believe one member indicated otherwise, but he was in Finland??
Amazon in Australia had 4 of the Posh relays, but they won't ship to America.
Anyone have any suggestions? Anyone with a 2017 do this?
The other thing that confuses me is I went on partzilla to compare the 2017 EX to the RS, and they indicate the same turn signals and the same factory relay. But I'm pretty sure most RS models I have seen online have the skinny LED signals, so I'm at a loss at this point.
Thanks for your replies!
03-08-2024, 03:57 AM
deuce17EX Offline
Threads: 3
RE: LED Turn Signals
Thanks for the reply!
So I just need to figure out which two wires to interrupt and connect them to that flasher and secure it down?
03-08-2024, 05:29 AM
mvk24_imp Offline
Threads: 18
Likes Received: 2 in 1 posts
LED Turn Signals
I think someone on here has definitely posted about using resistors that they wired in line. I could have sworn I've seen photos of their process.
It may have been on one of my write ups about when I did my micro LED conversion.
Personally I didn't mind the hyper flash especially with the micro turn signals because I think it catches other drivers attention better so I have not made any attempts to stop it.
03-08-2024, 06:00 AM
deuce17EX Offline
Threads: 3
(03-08-2024, 05:54 AM)m in sc_imp Wrote: its the ones that go TO the turn signal switch, the power IN. No, i don't know what color that is mines stock and never looked into it on THIS bike. I did just peek at the microfiche and it has a square, multi pin relay (thanks honda) so that one i listed prob wont work.
(see item 9) https://www.partzilla.com/catalog/honda/...re-harness
why wont resistors work? theres def room in the back under the seat for it?
I'm pretty sure I saw a few posts where the resistors weren't cutting it for whatever reason. Maybe heat, efficacy, etc. So then the $100 was coughed up for the Posh unit and everyone was soaring on rainbows again.
If I were to go the resistor route, does each signal require a resistor soldered in-line? Is the resistor then rated to the same specs as the bulb wattage or is it more complex than that?
03-08-2024, 06:13 AM
The Gecko_imp Offline
Threads: 43
Why cutting wires when all you need is to replace the bulbs in the CB’s turn lights with LED bulbs which fit straight in, mechanically and elec.
I like your user name.
03-08-2024, 07:05 AM
Threads: 43
Not a sin, but the CB’s turn signals look great on this bike. Compare this to the oem turn signals of a Z900 RS.
03-08-2024, 07:15 AM
deuce17EX Offline
Threads: 3
(03-08-2024, 07:05 AM)The Gecko_imp Wrote: Why cutting wires when all you need is to replace the bulbs in the CB’s turn lights with LED bulbs which fit straight in, mechanically and elec.
I find the turn signal housing assemblies a little too.....how do I put this.....HUGE. I prefer something like what's on the RS models. Or a smaller bullet shape.
03-08-2024, 07:21 AM
deuce17EX Offline
Threads: 3
(03-08-2024, 07:27 AM)m in sc_imp Wrote: im not 100% sure what you are looking for but i have a set of these on a bike and they are really nice. also no need for a flasher change as they use incandescent bulbs. would recommend. https://www.ebay.com/itm/235195710931?mk...media=COPY
Thanks for the offer, but I'm looking for an LED setup.
03-08-2024, 07:38 AM
mvk24_imp Offline
Threads: 18
I find the turn signal housing assemblies a little too.....how do I put this.....HUGE. I prefer something like what's on the RS models. Or a smaller bullet shape. I'm with deuce on this one.
I purposely went to the micro LED signals because the factory turn signals were not only large and gawky IMO but were also big enough that they interfered with aftermarket saddle bags that I use.
03-08-2024, 11:00 AM
deuce17EX Offline
Threads: 3
(03-08-2024, 09:55 AM)m in sc_imp Wrote: Im not selling them lol. i like them because they are visible, flashing, from the side and extremely well made. either way, the resistor advice i gave is sound.
LOL....D'oh! Sorry for the misread! I'll check into wiring in the resistors. I saw revzilla sells a setup pretty cheap. I have to check the wattage of the current bulb. And I still need to decide on a turn signal to buy. Thanks again!
03-09-2024, 12:33 PM
  LED turn signals Elipten_imp 32 2,518 01-05-2023, 05:15 PM
Last Post: CptMoustache_imp
  Any aftermarket Turn signals plug and play? gretle_2.0 5 689 05-30-2022, 07:05 AM
Last Post: bioman_imp
  Turn signals option USA in EU Łukasz_imp 7 688 02-08-2022, 12:18 AM
  Identify these? Turn signals RandyBMC_imp 3 383 11-11-2021, 09:23 PM
  Anyone fitted Rizoma iRide turn signals to CB1100EX? Richard_imp 8 822 05-20-2020, 09:58 PM
Last Post: Richard_imp
  Lockhart Phillips Turn Signals-Lucas Tail Light ChipBeck_imp 43 3,295 04-17-2020, 07:25 AM
Last Post: gman_imp
  RELOCATION OF REAR TURN SIGNALS ART_imp 28 2,043 02-08-2019, 01:50 PM
  Self canceling turn signals Obleo 19 1,141 04-24-2017, 08:10 PM
Last Post: Tezza_imp
  Replacement turn signals Mikestib1_imp 5 580 11-19-2016, 10:48 AM
Last Post: flynrider
  Hard bags without moving the turn signals glynb_imp 3 332 07-29-2016, 09:52 PM
