valve stem replacement without removing tyre
max Offline
Threads: 39
Likes Received: 15 in 8 posts
Whilst buying 90 degree valves for the cb919 i looked at some video's on how to install them, i then found this valve stem that you can replace without removing the tire.
Never seen this before and thought it may be something small for the rider to carry with the bike for the traveler that already has everything he needs;
Valve failures are rare but there may be a place for something like this, anyway now we know it exists: quickstem;
https://www.youtube.com/watch?v=BsXUC9fyiMU
01-08-2021, 05:08 AM
Gone in 60 Offline
Blood Biker of the Apocalypse
Orange County, CA
Threads: 245
Likes Received: 1,196 in 513 posts
Likes Given: 972
RE: valve stem replacement without removing tyre
Huh. I did have a valve stem fail on a BMW years ago. At least it wasn't a sudden release causing loss of control. This would have come in handy!
01-08-2021, 05:13 AM
Neat max.
Similar concept to "Wellnuts" used in some motorcycle windshield fasteners.
01-08-2021, 05:44 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
I can imagine there may be emergency instances where a valve stem is damaged, like a lock/chain left in place, or sabotage, and this would be a good emergency fix, But I personally would not trust it as it relies on compressing the rubber in a way that might cause a split or crack.
01-08-2021, 07:58 AM
Houtman_imp Offline
Threads: 115
(01-08-2021, 07:58 AM)pekingduck_imp Wrote: I can imagine there may be emergency instances where a valve stem is damaged, like a lock/chain left in place, or sabotage, and this would be a good emergency fix, But I personally would not trust it as it relies on compressing the rubber in a way that might cause a split or crack.
I feel the same as you , alright on heavy duty equipment going at a lower speed, different on a bike going 70-80 mph.
01-08-2021, 08:20 AM
peterbaron Offline
Likes Given: 996
I like Max advise as he meant in case of emergency and not as a permanent replacement: "something small for the rider to carry with the bike"
01-08-2021, 10:46 AM
  LED Headlamp Replacement Davidjill_imp 14 1,449 12-31-2024, 02:21 AM
  Yoshimura RS3 replacement for an '13 Jurlie_imp 7 676 07-28-2024, 01:47 PM
Last Post: Glockrocks83_imp
  Hepco Becker Replacement Key tomcat_imp 5 600 08-10-2023, 03:20 AM
   Quad lock stem mount Dunn2020_imp 5 538 06-07-2023, 12:36 AM
  Stripped the valve cover PowerDubs_imp 25 1,583 11-18-2021, 10:19 PM
  Wrecked my CB, need OEM or Aftermarket replacement suggestions danieljrmurray_imp 12 904 09-15-2021, 05:51 AM
Last Post: teamvisegrip_imp
   Clean pair valve..mod 3rdcoastcb1100_imp 14 1,191 05-22-2020, 09:58 AM
  Removing stock rack on 2014 quiffy_imp 10 709 05-17-2020, 01:23 PM
  Bar end weight replacement Gone in 60 12 1,094 04-12-2019, 11:42 AM
  INSTALLED: Rox Pivoting Riser 2" rise x 7/8 stem clamp x 7/8 " handlebar Mandrau_imp 11 786 10-24-2018, 12:29 AM
Last Post: Mandrau_imp
